Old 12-04-2014, 11:49 AM
Default R820T2 and Unitrunker
Can I use the R820T and the R820T2 with Unitrunker or does it have to be two R820T dongles, thanks.
MB
Old 12-04-2014, 12:35 PM
Jay911's Avatar
The implication is that the R820T2 should work. I don't know anybody who's tried it yet, but I've been contemplating getting a couple myself.
Old 12-04-2014, 2:36 PM
Thanks Jay, I just got one (r820t2), wasn't too successful at getting it up and running with the r820t and the r820t2 so I was beginning to think that maybe it wouldn't work. Guess I will give it another shot.
MB
Old 12-04-2014, 10:30 PM
Seņor Member
The best information I have is the R820T2 should work. The R828D does not work.
Old 12-04-2014, 10:40 PM
jpryor's Avatar
R820T2 works great with unitrunker. More stable and less noise and problems than the R820Ts. Would be worth the investment.
Jeff Pryor KC8NNO
Nashville / Green Hill TN
Old 12-05-2014, 6:07 PM
I've been using the T2 version for the past 3 weeks as my signal decoder in Unitrunker.
For the voice decode I use the .5PPM crystal version of the standard stick which also works with Unitrunker though I am using SDR# because of its displays. I'm also using an experimental driver for SDR# for the past week that allows you to tweak the auto-gain settings.
