  #381 (permalink)
Old 01-07-2018, 8:10 PM
Originally Posted by BM82557 View Post
I haven't been able to get the compile to work either. I've downloaded and extracted the jmbe_builder zip file and run the Make_jmbe_library_windows batch file. It creates a folder labeled jmbe but I haven't been able to find jmbe_0.3.2.jar file file. I-m running Win 7 64-bit and have Java 8.0_73
Found a post from last year that says "the JMBE auto-builder requires you to have the (Java Development Kit) version installed and the JAVA_HOME environment variable setup. I have to update the instructions on the wiki." Don't believe I have the development kit.
Where the heck do you set the JAVA_HOME at? Been trying ot get JMBE going without luck because of this and poor instructions on the JMBE Wiki.
  #382 (permalink)
Old 01-08-2018, 10:23 AM
BM82557's Avatar
This post is what I used as a guide =
https://forums.radioreference.com/2537065-post135.html
This how I set JAVA_HOME =
https://forums.radioreference.com/2537067-post136.html
  #383 (permalink)
Old 01-09-2018, 4:29 AM
We're you able to get the jmbe library compiled, or do you still need help?
Denny
  #384 (permalink)
Old 01-13-2018, 11:52 AM
Default Is there a manual for dummies.........
I have used SDR's before for finding talkgroups and information and I ran across this program and thought I would try it. I have downloaded everything that is required on web page. I have the SDR tuner recognized. How do I start getting information from the frequency I have entered? Is there a youtube video or such to walk us thru the whole process? Thanks for any help that can be offered It looks like an awesome program.
  #385 (permalink)
Old 01-13-2018, 3:50 PM
This is a screen shot of only thing I can view
  #386 (permalink)
Old 01-13-2018, 5:08 PM
The User's manual is here: https://github.com/DSheirer/sdrtrunk...rManual_V0.3.0
and the specific page on setting up channel configurations is here: https://github.com/DSheirer/sdrtrunk...hannels_V0.3.0
You'll have to create a channel configuration that identifiers the source frequency and the decoder to use, and then any optional logging or recording. Then enable the configuration and it will start decoding.
Denny
  #387 (permalink)
Old 01-13-2018, 6:08 PM
  #388 (permalink)
Old 01-15-2018, 11:31 AM
Default Can't find priority setting
Denny, I am running the latest version of java and SDRTrunk. When creating an alias, I can't find anyplace to set a priority for the talkgroup. Was this feature eliminated, or am I missing something? I am running this on Windows 10.
Craig
  #389 (permalink)
Old 01-15-2018, 8:07 PM
Craig, after you select an alias, you should be able to add an Audio Priority with the 'New' button on the Audio/Identifier tab in the alias editor.
If you've already assigned an audio priority and/or if you have assigned a priority of 'Do Not Monitor', the 'New' button won't give you the option to add another priority.
Denny
  #390 (permalink)
Old 01-16-2018, 9:54 PM
Default Thanks!
Wow, that was there all along and I could not find it. Thanks for pointing me in the right direction. It works like a charm. Is there a way to program a hold time for a particular talk group so that the program doesn't start scanning for other active talk groups right away ? Sometimes the dispatcher is slow to answer and the program will roll to the next active talk group, interrupting the conversation.
  #391 (permalink)
Old 01-17-2018, 4:25 AM
Talkgroup hold is not yet implemented, but there's an issue to add that feature.
