lets say I have a .wav file that I will call xyz123.wav. what is the syntax to play it back so I can analyze it. I have tried several different things and none have worked.
c:\users\yada\yada\DSDPlus-1.51>dsdplus.exe -fr ? xyz123.wav
3 frequency records loaded
processing input file 'xyz123.wav'
input file: fmt block was expected, but not found
WAV header processing error - aborting
c:\users\yada\yada\DSDPlus-1.51>_
is about all I get.
the .wav file is in the same folder as DSDPlus.
is about all I get.
