1. On a P25 system I follow, Unitrunker doesn't believe that radio-to-radio calls and individual transmissions in them are active the complete time they actually are and I miss audio. The call history is only showing one side's transmissions and Unitrunker is releasing from those before they are finished. Would it be possible for Unitrunker to delay retuning a voice receiver/assume the transmission is still in progress by looking at the signal or squelch level? Or would a log be helpful to see what's going on?
2. The health rate for that system never gets above 66 or 67, and a person I know who was/is involved with the system has noticed that since day one. Could this be because it's from EADS and not Motorola? I can get higher health rates on another regional, Motorola P25 system in the area, and I don't think it has to do with my location.
3. If you're using two RTL SDR voice receivers, is there a way to tell them apart in sdrsharptrunking.log (or does the log only work for debug receivers)? I was wanting to send each audio/metadata stream to a copy of Trunking Recorder.
4. I would like it if an audio stream could be sent to just the left or right side input instead of both sides.
