DSDPlus 1.071 Released
DSDPlus
Today is DSDPlus 1.071 release day. Stand by for a link to some shady website...
DSDPlus
Aye, ye still be needing VAC or somesuch for a bit longer.
All ye varmints head over to DSDPlus and grab yer booty.
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
Thanks very much for your time and efforts. Starts right up and works. Looking forward to digging into the more advanced features and considering the Fast Lane as it develops.
br0adband
Springfield MO
Timing is everything I suppose... just figured I'd check in this morning and voila, a new "toy" to play with for a bit.
Working great so far doing some basic DMR monitoring this morning of some casinos in town - housekeeping departments are all over the place as expected. ;)
n4yek
Newport, Tennessee
Bug found??
In v1.051 when you close the 'Channel Activity' window, it will close.
In v1.071 when you close the 'Channel Activity' window, the program closes down.
Bug #2
1) When I start the program, it will not show NXDN Alias on the voice channels in the Event Window
2) When I look at the control channel, it will see the alias that is transmitted on the control channel in the Event Window.
3) When I go back to voice channels, now alias's are showing in the Event Window.
Now most of the NXDN traffic i have is Encrypted and the above steps corrects the alias until an un-encrypted talkgroup come on and then the 'Event Window' stops showing 'alias' again just a few transmissions later.
Have to repeat steps 1-3 to make it start showing up once more.
No NEXEDGE aliases at all here. If there is some command to enable it now I can't find it.
Same here it's not working in this build.
Try what I found in Bug #2 and see if that fixes yours, just curious.
nd5y
Wichita Falls, TX
I don't know what you mean by "looking" at control and voice channels. I tried clicking, minimizing and restoring all windows and that didn't do anything.
All the NEXEDGE repeaters here are conventional so there is no control channel.
RonnieUSA
Rowan County,KY (Morehead)
Same here also no trunking, just conventional.
KC1UA
I'm also seeing pretty much the same behavior regarding alias info as described in post #12. I started on a NEXEDGE48 CC, then learned how to use the scan feature of FMP. When I started scanning with it I started seeing alias info on all system channels.
Great great job on FMP, what a nifty addition!
n4yek
Newport, Tennessee
Sorry Ronnie and ND5Y, i have trunk systems here where i live.
Bug #2
(update) Watching this more, doesn't matter if it's encrypted or not. After a period of time, it will revert back to not showing alias. Seem to be around 5 minutes plus or minus a minute from what I am seeing
garys
I downloaded and installed the program without a problem. The problem I do have is that when I press ESC to close the program to reconfigure the audio input and output, the window closes. How do I get that window to stay open? I don't recall what, if anything, I did for the previous version.
Ignore the above. I figured out that I had to edit the DOS window I created to point to the correct Directory.
Once I did that, it started fine and I dialed in a three channel trunk site (MotoTrbo) that has the three channels adjacent to each other. I can see activity on all three at one time, which makes jumping around easy.
Can someone tell me where the records are saved? I assume it's a text file, but I'm not sure where.
I also saw a notation that auto muting was enabled because of an encrypted TG. I didn't catch the TG number.
And of course I have to figure out what to do with aliases. Time to read the help file.
Good work by the developers, thanks.
vince48
Central Valley, CA.
Great, thank you. Can't wait to get home tonight and play. Unless I missed something (forgive me If I have) what does "FMP" stand for. Again, thanks much.
vince48
n4yek
Newport, Tennessee
vince48
From the folder of DSDPlus:
FMP.txt
FMP is a simple DVB-T dongle tuner / NFM demodulator. It samples at 1 MHz,
so its spectrum display spans 1 MHz of the RF spectrum. FMP is designed for
low power devices like low end netbooks where CPU and screen resources are
limited.
