Or:
use a scanner with a built in tap to begin with. PRO-668's can be had on the cheap lately ($180-$200).
Install DSD 1.074 (
DSDPlus | Digital Decoder)
Save and extract the files
Turn your 668 on, go into its settings and set IF (discriminator audio) to "HP" or "HP/SP".
Connect a 1/8" to 1/8" audio connector cable to your scanner and the other end to your computer
If it is a laptop youll need a cheap sound adapter cable, 3 line 1/8" prong y'ed to a mic input and headphone/speaker output. In this case connect your cable from your scanner to the red mic in input on the sound adapter cable. For desktop use the "line in " input on the back of your desktop.
Go into computer sound settings and make either line in (desktop) or external mic (laptop) your default comm device.
Tune your scanner to the digital channel of your choice.
Open DSD
right click on the line that says DSD application.
Run DSD as Administrator
position your DSD boxes neatly on your screen for easy viewing
Watch the data start to fly!
Tips: tune to a TRBO Connect Plus control channel or P25 control channel so you'll know right away if you are getting decoding.
Check your DSD source audio box to make sure you are getting a signal. If you're not, you need to recheck your computer sound device settings and scanner set up.
Any luck yet?
