  #81 (permalink)
Old 10-09-2017, 8:51 AM
mrscanner2008's Avatar
Hi
I have a problem with fmp24: when I start a scan, FMP24 didn't stop on frequency with signal, is there a way to force FMP24 to stop on a frequency until no signal?
thanks
WWW.VE2DRO.COM
Icom IC-91AD, Yaesu FT-8900R, Icom IC-7000, KX-3, FTM-400DR (Fusion),Icom IC-R20, BCD396XT,(2)BCD996XT, PSR600, HomePatrol 1, (2)BCT15X, (2)BCD436HP, BCD536HP and TRX-1
  #82 (permalink)
Old 10-09-2017, 9:14 AM
What mode are the frequencies? Have you specified the mode in your scanlist for each frequency?
AM or FM
This is the scanlist format
118.3 AM BW=12.5 DELAY=2 Miami Tower
This example forces AM mode for the frequency.
Also the DSD+ switch should be selected for the correct effect.
DSD+: Added raw source audio monitoring modes
The -m<num> command line option and the M/m active keys select one of the five
available monitoring modes:
  #83 (permalink)
Old 10-09-2017, 8:15 PM
What kind of signal? Analog or digital voice? What version of FMP24?
  #84 (permalink)
Old 10-10-2017, 7:31 AM
Only digital voice.
I'm using DSD FL 2.39.
@DRL-XM43:
All FM and yes I specified the mode in the scanlist.
WWW.VE2DRO.COM
  #85 (permalink)
Old 10-10-2017, 5:00 PM
tried delay=2 but no succes, fmp24 didn't stop on signal.
here is my fmp24.scanlist :
143.1600 DMR BW=12.5 DELAY=2 CTMThetfordmines
143.3850 DMR BW=12.5 DELAY=2 CTM MT Adstock
148.1200 FM BW=12.5 DELAY=2 INCONNU
149.5500 FM BW=12.5 DELAY=2 INCONNU
150.5000 FM BW=12.5 DELAY=2 INCONNU
151.9250 DMR BW=12.5 DELAY=2 INCONNU
152.4800 DMR BW=12.5 DELAY=2 INCONNU
154.1150 CAP+ BW=12.5 DELAY=2 BoreaConstructio
162.4200 DMR BW=12.5 DELAY=2 telecomdenisgign
163.0350 CAP+ BW=12.5 DELAY=2 BoralexStFereole
163.0950 NEXEDGE96 BW=4 DELAY=2 shawi
163.6650 NEXEDGE96 BW=4 DELAY=2 shawi
164.2050 NEXEDGE96 BW=4 DELAY=2 shawi
164.7450 NEXEDGE96 BW=4 DELAY=2 shawi
and I use -m1 in my DSD+ batch:
dsdplus.exe -m1 -v4 -T -E -Pwav -wsl400.2 -wss100.300 -wel0.1 -wcl44.27 -wch13 -wes400.900 -H0 >>DSD+.log
what is my problems ???
WWW.VE2DRO.COM
  #86 (permalink)
Old 10-10-2017, 7:07 PM
You don't seem to have DSD+ listening for a port or a audio device like vb-cable or something like this
Start FMP24.exe -i2 -o20020 -P0.0 -f141.930 -q1 -a1 -v120 -s1 -g49.6 -_1
Start DSDPlus.EXE -i20020 -f1 -m1 -_15
-o for FMP24 to send on TCP port
-i for DSD+ to listen on TCP port
PS That batch file example should work for you but I would add "timeout /t 5" in between the 2 commands to avoid connection timing issue
  #87 (permalink)
Old 10-10-2017, 9:31 PM
What is the DSD+ working folder?
What DSD+ path is FMP24 using?
And you didn't answer the FMP24 version question...
  #88 (permalink)
Old 10-11-2017, 6:09 AM
@DRL-XM53:
my fmp24 batch file:
FMP24.exe -i1 -o20001 -P60.5 -b12.5 -rc
@slicerwizard:
What is the DSD+ working folder? c:\DSD239
What DSD+ path is FMP24 using? c:\DSD239
And you didn't answer the FMP24 version question... FMP24 2.19
my DSD working fine for decoding and following trunking, it's just FMP24 that didn't stop on active frequency when scanning.
WWW.VE2DRO.COM
  #89 (permalink)
Old 10-11-2017, 4:03 PM
Yes, I use FMP24 and a scan list. In DSD+, I use monitoring mode 1 (monitor if no sync and signal present). -m1 on the DSD+ command line selects that mode and DSD+ passes the analog audio to the speakers.
Slicerwizard
Since I joined Fastlane I have been converting my public release scan setups to FL FMP24 and companion DSD.+
I have a weird problem though, all of the setups which have the frequency stated in the batch file (like trunking) or single frequency scan work great and DSD+ gives clear voice audio..
However, all the setups that use FMP24 scanlist , then DSD+ is a sound mess. The scanning function works as it should.
The same setups in public release work fine?
I am guessing I am missing something in the area of FMP24 scanlist (the common thing in this), I have tweaked and twidled but cannot find an improvement.
Do you have any ideas?
Thanks,
Doug.
  #90 (permalink)
Old 10-12-2017, 12:18 AM
So you were using FMP before and are now using FMP24?
IIRC, FMP uses a 1 MHz sampling rate while FMP24 uses a 2.4 MHz sampling rate. Is it possible that your computer can't keep up with the higher rate? Can you make and upload a raw audio recording from DSD+ while FMP24 is tuned to a good signal? Maybe some problem in it will be obvious.
  #91 (permalink)
Old 10-12-2017, 11:12 AM
Hi Slicerwizard
Thanks for helping.
Ok prob solved, it was a hw issue. I have dongle 1 & 2 each with an antenna. It turns out D1 had a weak signal, so it depended which dongles were selected in the batch whether it worked properly or not. Why it was confusing, some scans were good others bad depending on the signal.
So, I fixed the loose antenna connection on D! and all is good now - D1 & D2 both receiving properly now.so all decoding is good :-)
I guess I should have checked signals more often (DUH)
Anyway, thanks again,
Best regards,
Doug
  #92 (permalink)
Old 10-12-2017, 12:05 PM
so no one can't help me for my problems ?
WWW.VE2DRO.COM
  #93 (permalink)
Old 10-12-2017, 12:17 PM
You said you had -m1 selected for DSD+ ? Try removing the mixed mode types in the FMP24 scanfile so there is only one type. Do this for each type and see if any of them work correctly.
You had quite a mixture in the scanfile, it would be hard to test with such a mixture. Let us know.
  #94 (permalink)
Old 10-12-2017, 12:33 PM
Hm, copy the contents of FMP24.cfg into your next reply.
  #95 (permalink)
Old 10-12-2017, 12:56 PM
2.4 ; sampling rate (1.0, 2.0 or 2.4)
1024 ; spectrum window width
64 ; FFT size (16k, 32k, 64k)
20 ; spectrum update rate in Hz
5000 -6250 7500 12500 15000 25000 ; step size table; units = Hz; negate default
c:\dsd+239 ; DSD+ path
.\FMP-FreqList.csv ; primary frequency list CSV path\filename
.\FMP-FreqList2.csv ; auxiliary frequency list CSV path\filename
kilometers ; search units (miles or kilometers)
99.9 ; search distance
19.7163 -155.6241 ; search origin
WWW.VE2DRO.COM
  #96 (permalink)
Old 10-12-2017, 11:12 PM
You might want to fix that.
  #97 (permalink)
Old 10-13-2017, 7:29 AM
why? because all DSD+ works fine except FMP24 that didn't stop on signal.
If I manually tune a frequency in FMP24, DSD will decode fine.
but I will correct this for just DSD+ and try if this resolve my scan problem.
WWW.VE2DRO.COM
  #98 (permalink)
Old 10-13-2017, 5:32 PM
If FMP24 doesn't know what folder DSD+ is using, the two programs don't communicate properly. And then FMP24 doesn't know if it's scanning stuff that is of interest to DSD+, so it won't stop on traffic...
  #99 (permalink)
Old 10-15-2017, 6:15 PM
Hi
I change the name of the folder (DSD239) for the DSD default, but FMP24 doesn't stop on signal.
I also tried just the same mode in the FMP.scanlist (just Nexedge or just DMR) but no succes, FMP24 didn't stop on signal, it just continue to scan.
WWW.VE2DRO.COM
  #100 (permalink)
Old 10-15-2017, 11:37 PM
Hi
My suggestion is to
1) create a new folder, place a clean stock set of DSD+/FMP24 files in it (As sent to you) from FL.
2) then place your FMP24 scanlist and startup batch file in it also.
This at least takes away all the confusion about paths, cfg settings and versions so you have a clean baseline to work with.
I would use a simple batchfile like this to start with
: Change the device#(I) ppm(P) and gain(g) to suit
Start FMP24.exe -i2 -g49.6 -o20001 -P0.0 -q1 -s1 -_1
timeout /t 5
Start DSDPlus.EXE -i20001 -OM NUL -_3
timeout /t 5
You could use this as a copy paste for your batch file - it should work.
Let us know.
Your scanlist format
Perhaps make the frequency xxx.xxx instead of xxx.xxxx
Remove the BW statement (let fmp auto the bandwidth)
