bama9999
I'm having a bit of trouble trying to hear a Provoice system while using Unitrunker and DSD+. I'm using a BC355N with a discriminator tap for my signal source, and everything is ok with that, and it's trunking the system like it should. I'm using one of the RTL dongles for the voice receiver and that seems to be where the problem is. I tried the dongle as the signal receiver, and it receives the control channel fine, with a health of 98 to 100 most all of the time. It's just when it's used in the voice receiver roll that it doesn't seem to work right.
The audio is not decoding good at all in DSD+, and also there's a lot of what sounds like static between voice calls, and I've tried maxing out the squelch and it doesn't help.
Also, if I just scan the voice channels of this system conventionally, and pipe it into DSD+ from the discriminator tapped BC355N, it sounds great, but when going through Unitrunker with the dongle, I get the bad decoding and the static noise, which is present with the garbled decode.
I hope I was clear enough, but I'll be glad to add more info if needed, if anyone has any ideas or suggestions. Attached in a pic of the waveform of the static/interference/whatever, and also two shots of my audio receiver in Unitrunker.
Any help appreciated.
