OP doesn't indicate if he is using a repeater or simplex. The different performance on timeslot 1 vs 2 sounds like another audio loopback setup (DSD+ hearing itself)
Thanks jhampton2000 and slicerwizard
For your questions !!
jhamptonn2000 for the sound card is fine and the left channel and the right are balanced ...
slicerwizard and a repeater and it works on both the TG1 and TG2 ..
I tried to use as program SDRSharp and everything works perfectly the voice comes perfectly with the same level on both the TG1 and TG2 ...
I assume that the problem is on the FMP program, perhaps there to do a schedule other than that I do ..
and this configuration as the use:
echo off
cmd / c FMP 2 1 32 435 175
PAUSE
exit
Do you have any advice for me?
