I know this has to be an issue of user error somewhere but I'm unable to figure it out. Here is copy of the CC log it's giving a TCP error but I'm not real sure what needs to be changed, any help here would be appreciated.
Thank You,
Rob
DSD+ 1.092pt
Program role is control/rest channel decoder
Source audio waveform window origin set to (400,2)
Source audio waveform window dimensions set to 100x200
Event log window origin set to (0,1)
Channel window origin set to (0,445)
Event log window dimensions set to 400x520
Appending synthesized audio to file 'CC-DSDPlus.wav'
4 frequency records loaded
0 radio records loaded
0 group records loaded
1 site record loaded
0 network records loaded
Connecting to TCP port 20001...
audio output device #1 = 'Speakers (Realtek High Definiti'
audio output device #2 = 'Line 2 (Virtual Audio Cable)'
audio output device #1 (Speakers (Realtek High Definiti) initialized
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
TCP connect error = 10061
[No connection could be made because the target machine actively refused it]
Connected to TCP port 20001
Sync:+DMR
+DMR slot1 BS DATA DCC=8 CSBK Con+ NL = 6 8 7 5 1
+DMR slot2 BS DATA DCC=8 Idle
+DMR slot1 BS DATA DCC=8 CSBK ERR1 Con+ NL = 6 8 7 5 1
Network=123 Site=4
Network=123 Site=4
Thank You,
Rob
DSD+ 1.092pt
Sync:+DMR
Network=123 Site=4
Network=123 Site=4
