mitaux8030
Silent Key
I'm having troubles with poor/zero decode rate on DSD+ v1.074 with 9600bps digital voice, on a HP 6730B laptop.
Here's how things have gone down so far:
PC A is a desktop.
PC B is a laptop, as above.
RX Y is a BC780 with discriminator tap installed.
RX Z is an Pro2006, with discriminator tap installed.
Receiving a clean & strong 9600 provoice signal.
PC A + RX Y = good decode.
PC A + RX Z = good decode.
PC B + RX Y = no decode at all.
PC B + RX Z = no decode at all.
Then I saved raw files, and swapped them between PCs:
PC A + RX Y recorded, then transferred to PC B: good decode.
PC A + RX Z recorded, then transferred to PC B: good decode.
PC B + RX Y recorded, then transferred to PC A: no decode at all.
PC B + RX Z recorded, then transferred to PC A: no decode at all.
From the above, I conclude that both receivers are working just fine, and that PC A and PC B have the computing horsepower to successfully decode from files, and that the DSD+ software is working on either PC without problem. The problem appears to be PC B's (the laptop) ability to accurately sample the discriminator tap being input to it.
For comparison, I have included a picture of the scope being used on PC B while decoding from a 'good' and 'bad' recorded .wav file. Not much difference between the two is there? And listening by ear, there's barely any difference between the samples either.
I've tried inverting polarity, which made absolutely no change. I've tried tweaking input levels on the laptop, again no dice. AGC / microphone boost is off for the microphone input. What else can I do to improve things?
Interestingly, PC B live input seems to decode OK when tuned in to a 4800 DMR system.
For reference: Laptop is a HP 6730b, running WinXP, and for whatever reason I have been unsuccessful in getting the microphone socket to work as a line in port. It'll only work as a microphone input.
PC A is a desktop.
