May I suggest for those of us running SDR sticks or other multi-VCO-capable receivers:
- a visual indication in site picker, direct frequency entry, or etc., that the frequency you are trying to choose is outside the range the VCO can be tuned to (dependent on what your other VCOs are tuned to). For example, in Site Picker, freqs outside your bandwidth range might be shown as red instead of black font color.
and/or:
- Automatic setting of the bandwidth to expand or contract as necessary to allow the frequency being input to be monitored (i.e. if my current setting is 0.90 MSPS and I key in a frequency that is 1 MHz "away" from what my other VCO is set to, my receiver is automatically reconfigured to 1.024 MSPS)
And also:
perhaps a little more explanation of how Unitrunker treats multiple VCOs. Is one of the VCOs favored over others when it comes to deciding if a frequency can be tuned? For example, if I have two VCOs tuned to 769.x MHz frequencies (within that 1 MHz range), and then try to tune VCO 2 to a 774.x MHz frequency, obviously I'm not going to be able to span that range, and I will not successfully tune VCO 2. But if I then try to tune VCO 1 to a 774.x frequency, will both VCOs 'wake up' and decode? Put another way, if a VCO is "unsuccessfully" tuned to a frequency because it was outside the range compared to what VCO 1 was set to, does a subsequent tuning of VCO 1 have to land "in range" of the frequency VCO 2 is set to in order to receive a signal?
and/or:
And also:
