Hi all,
I would like to start a thread on how RAS works to un-mute the audio of existing 2-way radios. I understand it's in a CRC/check sum/coding scheme is a certain field or fields. Which field affects RAS and how would the Checksum differ from a non-RAS implementation?
Fields that a FEC and/or check sum are performed in DMR:
(taken from the CML CMX7341 PMR/DMR Common Platform Processor chip data sheet)
EMB field
Slot Type
CACH TACT bits
Embedded signalling
Reverse Channel (RC)
Signalling Short LC in CACH
PI Header
Voice LC header
Terminator with LC
CSBK
Idle message
Data header
Rate 1⁄2 data continuation
Rate 1⁄2 last data block
Rate 3⁄4 data continuation
Rate 3⁄4 last data block
Rate 1 non-last data block
Rate 1 last data block
Response header block
Response data block MBC header
MBC continuation MBC last block
UDT header
UDT continuation UDT last block
EMB field
Slot Type
CACH TACT bits
Embedded signalling
PI Header
Voice LC header
Terminator with LC
CSBK
Idle message
Data header
UDT header
