Though I am decoding dmr, and hearing clear audio, I see in the window the following.
Listening on TCP port 20001
Accepted connection from localhost on port 52384
TCP error = 10035
[A non-blocking socket operation could not be completed immediately]
Accepted connection from localhost on port 52386
Etc Etc
Whats causing this and how do I fix it?
WSAEWOULDBLOCK 10035
Resource temporarily unavailable. This error is returned from operations on nonblocking sockets that cannot be completed immediately, for example recv when no data is queued to be read from the socket. It is a nonfatal error, and the operation should be retried later. It is normal for WSAEWOULDBLOCK to be reported as the result from calling connect on a nonblocking SOCK_STREAM socket, since some time must elapse for the connection to be established.
TCP error = 10035
Etc Etc
