I have unitrunker up/calibrated/& running, and it has been for months, however as more site on the system I monitor come online I have run into this problem...
I can put one site in a VCO, it receives with 100 percent health, I can go to another nearby site using still the single VCO, just changing the frequency, and it decodes with 100 percent health, however when I add the second VCO and try both simultaneously one of them will drop out and maybe barely marginally decode or not at all....
The sampling rate is set correctly and both frequencies are within range.
Has anoyone had an issue like this? Could be a hardware issue too, however checking with SDR# I can see both spikes, and several other distant sites no problem....
