DSD help
Czollars
Group,
I've got Unitrunker up and running and have also installed Virtual Audio Cable. I can run DSDPlus from the C:
\ command prompt. What is the DSDPlus command to run the virtual audio cable 1 as the input, and my PC speakers as the output. I can't get it to run. I am trying to decode Apco 25 digital audio. Please help, I'm stuck. Are there online instructions?
Chris
cg
Connecticut
The help is in the program and can be extracted easily
DSDPlus -h >DSDPlus_help.txt
You then can read, print, use the help file created by the program.
chris
reconrider8
Eastern, NC
First off you need to know what your input and output settings are. Ie run dsd in cmd and see what the options are. So if your vac is imput 1 and speakers are output 1. This would be how you would run... /dsdplus -i1 -o1
cg
Connecticut
-i1 and -o1 are the defaults so if you tried running it by just using DSDPlus, it likely will not work with those options enabled.
I am guessing that the Virtual Cable is not input 1. Usually, that is the computer inputs (microphone or line in)
When you start the program, there's a list of inputs that are seen by the program
chris
