Like the P25 trunking support in this version
I have been monitoring the Michigan Public Safety Communications System (MPSCS) using two radio shack scanners and a separate laptop PC setup with Universal Trunker, virtual cables and three SDR-RTL dongles. The laptop setup allows me to monitor any two talk groups on my local site simultaneously as the they become active. I pipe one voice receiver through the left channel and the other through the right. The two radio shack scanners are setup to monitor a few other more distant tower sites. This combination allows me to monitor five counties at once through four speakers. I don’t miss much but, it does get confusing at times.
I loaded DSD+ Fastlane 2.5 last night as soon as I received the email and after quickly reading the help/txt files. This version seems to be working very well on my desktop PC. Configuring this setup was easy. However, this configuration only lets me hear one voice channel using two dongles. It appears that there is not a way to use more than one voice receiver. I would like to see the capability expanded to two or more voice channels using multiple dongles, multiple instances FMP24 and multiple instances of DSD+ for voice channels. I want to be able to duplicate the capabilities I have with the three dongle setup on the laptop I described above.
The setup is easy in DSD+ Fastlane with the audio being handled via TCP. Having to use virtual cable drivers complicates the setup in the older setups using DSD+ and Universal Trunker. Don’t get me wrong, I am not knocking the setup I have using Universal Trunker. I really like Universal Trunker, however, I am hoping for performance gains by using FMP24, DSD+ and my dongles. I have not loaded the setup from my desktop PC to my laptop (Dell Inspiron E1405 with Intel Dual Core 1.66 GHz processor) to compare performance. The Dell laptop does OK but, it is working really hard and the audio breaks up when things get really busy.
Bottom line, after all said above is, can we please get multi-voice channel/receiver capabilities in a future release of DSD+ Fastlane. This is a great product, keep up the good work.
ETA:
I am noticing a few types of odd behavior when running DSD+ from the Fastlane 2.5 version:
1) On a system using Universal Trunker, the Ch and Tx Freq columns in the Channel Activity windows intermittently populate with information ,the information appears to be correct but, this never happened with the older versions. This occurs in either of the instances I have running, one window at a time.
2) When running DSD+, FMP24 and two dongles on the Michigan Public Service Communications System I see information in the Target and TgtAlias columns that appear to be call sign identification for a given system channel. It temporarily stops communication of the frequency of the audio channel from being passed to the voice channel side. It looks like the characters "bsi" appear in the Target column and the call sign of the transmitter appears in the TgTAlias column.
