CanesFan95
I'm running DSD+ on Windows 7 64-bit, and despite having a strong signal strength, I always get partly garbled audio no matter what I do with the audio settings. Sometimes the audio cuts out alltogether. I'm using SDR# with a RTL-SDR R820T2 RTL2832U 1PPM TCXO dongle. I have the same problem on a tapped scanner. What are some settings I should try? Here's some shots of the wave form and signal strength in SDR#. And, do these CACH ERR messages mean I'm doing something wrong? What's the best sample rate to choose, and should I change the setting under the Recording or Playback tab?
