D
DaveNF2G
Guest
I use a Uniden BCD-996XT as the voice following scanner with Pro96com. For times when I prefer not to run a computer to monitor (like when I am just listening and not watching CC data), I also have the particular P25 system programmed normally into the scanner.
When scanning the system, the 996 decodes digital audio perfectly.
When under Pro96com control, the 996 tunes to the voice channel but only decodes audio sporadically.
As the scanner should be using the same circuitry for voice demodulation in both scenarios, I cannot figure out what might be causing this. Does anyone have any ideas?
