It's determined by the emission designator. It is somewhat reliable. FMP-DSD+ is more forgiving in that regard, though. Many of them do have multiple emissions, namely analog FM voice. However, I've found that probably over half of the results are the correct format and perhaps even higher.
The county is from the location tab. Searching a state only with the county null should show everything authorized for statewide operation. Just as searching with both state and county blank does the same for nationwide.
However, this is not yet 100% accurate. I have not yet completed the back-end database work for this to be correct. So I do not recommend using that feature at this time. Additionally, some of the entries are county results that are erroneously not returning properly.
An example of nationwide operation:
ULS License - Industrial/Business Pool, Conventional License - WQSR889 - OXBOW CARBON LLC - Locations Summary
An example of statewide operation:
ULS License - Industrial/Business Pool, Conventional License - WNNH494 - APPLIED TECHNOLOGY GROUP INC - Locations Summary
In general, these are going to be very low yield items to search.
Some great suggestions in that list.
I added the callsign to the FMP search results. Also, if you search with the regular searches (DMR, P25, etc.), the call sign is listed and it links to the ULS entry on the FCC site.
2) That's available in the second search tool, but it might be letting some legitimate frequencies fall through the cracks, so it is a juggle. Alternatively, up the minimum power setting to eliminate most of the mobiles.
3) I'll ponder on this. My preference is to keep everything as simple and clean as possible. Also, some counties already yield thousands of results on their own.
4) What would you like to filter on? Some of the search tools offer sorting options. For FMP, it will be limited as each protocol will have to be listed segregated (but if you want to sort by frequency, it takes 10 seconds to copy into Excel before you move it to the ScanList file).
5) The data is from the July 10th FCC weekly release. This is on the query page, just under the searches specific to the relevant to the protocol. I was attempting to cut out some length.
I really appreciate your post. Having information like this gives me insight into what others find useful and will allow me to create better tools.
