Old 11-03-2016, 5:35 PM
W4KRR's Avatar
Default TIII systems: voice frequencies from channel numbers?
Using DSD+, I found a system that displays, at the bottom of the Event Log:
TIII Site:L13-1.1 DCC 1
In the Channel activity window, it displays channel numbers as follows:
1845
1846
2365
2366
2381
2382
I have identified two frequencies: 464.8625, and 464.7625.
Can the voice frequencies be determined by these channel numbers? Systems that identify as CON+ or CAP+ show the channel numbers as 1, 2, 3, 4, etc.
Ken
Old 11-03-2016, 8:00 PM
KevinC's Avatar
Moderator---not censor
Wild guess, but I'd try 461.5125...assuming my math is correct.
Someone told me signatures are silly, so I got rid of mine.
Old 11-03-2016, 8:54 PM
Hello,
Tier 3 can follow a classic Freq = (LCN - 1) * Step + Base formula. DSD+ considers each slot to be a channel, so 1845 and 1846 are the same frequency, for example. You need to divide the higher number by two to get the actual LCN. So the LCNs are:
923
1183
1191
You really need to tie at least one of the two frequencies you identified to the channel number.
It appears the 2365/2366 is 464.7625 and 2381/2383 is 464.8625, but the base frequency (LCN 1 = 449.9875) does not seem to be quite correct. I would try 461.5125 as suggested. That is possibly 1845/1846.
73 Eric
Old 11-03-2016, 8:59 PM
KevinC's Avatar
Originally Posted by EricCottrell View Post
Hello,
923
1183
1191
73 Eric
I used a base of 449.98125.
ETA...
With a channel spacing of 6.25 kHz.
Old 11-03-2016, 9:24 PM
W4KRR's Avatar
I think #2382 is 464.8625, and #2365 is 464.7625. I am monitoring 461.5125, but nothing so far. However it is nighttime and it may not be a busy enough system. I am also trying other frequencies while looking for the "Site L13-1.1" indication.
Ken
Old 11-03-2016, 11:32 PM
jonwienke's Avatar
If we're talking Tier III DMR/MotoTRBO, wouldn't the channel spacing be 12.5KHz? TDMA instead of FDMA and all that...
Old 11-04-2016, 10:09 AM
Hello,
I noticed Tier 3 voice channels on the Hytera systems around here look like DMR conventional. They do not carry site information, unlike Motorola. You need to monitor the control channel, wait for 1845/1846 to become active and then search while it is active.
73 Eric
Old 11-04-2016, 11:11 AM
KevinC's Avatar
In the context of how the radio actually works probably yes, but in the context of how DSD+ interprets the channel numbers this formula appears to work.
Old 11-04-2016, 11:13 AM
KevinC's Avatar
Based on your location, the 2 known frequencies and 1 suspect frequency, the below license is a likely candidate...
WPVZ205 (MIDWAY TOWER MANAGEMENT INC) FCC Callsign Details
Old 11-04-2016, 1:31 PM
Smile Citation Communications TIII
Some channels that I discovered, system not very busy, mostly taxi or shuttle service.
Citation Communications Lantana
461.5125 Ch 1845/1846
464.7625 Ch 2365/2366
Citation Communications Singer Island
451.9625 Ch 317/318
452.2125 Ch 357/358
464.8125 Ch 2373/2374
Old 11-04-2016, 1:38 PM
W4KRR's Avatar
Apparently this is the system. I have now confirmed:
1845/1846 = 461.5125
2365/2366 = 464.7625
2381/2382 = 464.8625
The system is right on the edge of me being able to receive it too clearly, but at least I have identified it. Thanks for the help.
Ken
Old 11-04-2016, 1:54 PM
KevinC's Avatar
Cool!
For any additional channel numbers use this formula...
Multiply the odd channel number by .00625 then add 449.98125 to the product for the frequency.
Old 05-19-2017, 1:47 PM
Can a DMR Tier 3 system have more than one base/offset or a different base/offset for different sites?
There is one near here that appears to have more than one band plan.
DSD+ 1.01 shows the following
Site 1-1.1
451.45 ch 3 and 4 (LCN 2)
452.025 ch 95 and 96 (LCN 48)
Site 1-1.2
The transmit frequency appears to be off. It's either 464.44375 or 464.45 and too low. There is no FCC license so I don't know what it's supposed to be.
DSD+ shows ch 323 and 324 (LCN 162). Either way it appears to be different than the other site.
If I use the formula posted earlier and change the base freq to match the first site then ch 323 should be 453.45.
Tom
Old 06-20-2017, 8:32 AM
Raccon's Avatar
The base can be different for different sites.
Rgds,
Raccon
Old 06-20-2017, 9:12 AM
Motorola's Tier 3 can have 4 different bases. I was told that this allows them to cover weird European freq plans AND allows multiple bands in one system (vhf, uhf, 800, 900, etc). TT
