Fix 'DSD Interface' plug-in for SDR# (for use with DSD+ v2.29 FL)
thewraith2008
For those who wish to continue using the DSD Interface plug-in
NOTE: This does not add any options introduced by DSD+ v2.29 FL
Fixs bug in plug-in and some changes that have occurred in DSD+
- Invert signal polarity (X2-TDMA or dPMR)
- '-dr' and '-dh' (Have been removed in DSD+ v2.29 FL)
see FixDetails.txt for more detail
Install
Backup old 'SDRSharp.DSD.dll'
Copy modified version of SDRSharp.DSD.dll into working SDR# folder
Cheers
  • FixDSDInterface.zip
dave3825
Suffolk County NY
My dsd looks different now when I use the plug in. In the pic below the left side is launched with the dsd plug in. The one on the right is launched without the plug in.
thewraith2008
Can't say for sure, Sorta looks the same. Is the DSD+ that is used by the plug-in the same as the one without? Is the 'Frame information verbosity' set the same?
The 'DSD Interface' uses additional command line options that you may not have in standalone version your running.
Open 'SDRSharp.exe.Config' with a text editor and look for 'DSDArguments' and 'DSDAuxArguments' to see what the command line will be. You can also use '-' but you probably won't see the entire line. Note: don't change from here as the change won't be persistent.
Hope this helps.
Cheers
49r
Thank you for the solution. Switched to DSD+ FL version yesterday and spent hours trying to make it work again. It's OK now — thanks to you.
thewraith2008
REDUX
I was having the "buffer lost" issue that is present in newer versions of SDR# 1.0.0.1533+
I applied what I did to last fix, to this "version" of the DSD Interface' plug-in and a little extra, see below.
Fix 'DSD Interface' plug-in for SDR# (for use with DSD+ v2.29 FL or higher)
by thewraith2008 in June 2018​
This version of DSD Interface plug-in:
  • Does not have "buffer lost" issue that is present in newer versions of SDR# 1.0.0.1533+
  • Has extra step in storing settings (see below).
  • The added commandline is less tolerant of mistakes, incorrect values/length will crash SDR#.
  • This is a bug in the plug-in, and NOT caused by this modification.
NOTE: This does not add any options introduced by DSD+ v2.29 FL or newer.
Fixs bugs in plug-in and some changes that have occurred in DSD+
  • Invert signal polarity (X2-TDMA or dPMR)
  • '-dr' and '-dh' (Have been removed in DSD+ v2.29 FL and higher)
  • "Create command line" would re-introduce -dr -dh (replaced with -m)
  • Corrected order of commandline that "Defaults" created. Now like what "Create command line" creates.
Install
Usage:
Change settings as normal, Click "Create command line" to store/save then OK to exit.
Failure to use "Create command line" will result in forgotten settings.
  • FixDSDInterface_2.zip
