M105
- Joined
- Sep 13, 2005
- Messages
- 399
I decided to set up a batch file to monitor my local NOAA Weather Station. I used the following command line:
FMP24 -i3 -P40 -o3 -f162.5500 -b12.5 -n2 -_1 -wsl6.6 -g49.6
Ok, it works fine but with one quirk being the initial bandwidth always gets reset to 7.6 instead of the 12.5 that I have specified.
FMP24 command window reports the BW set to 12.5 when it first runs but the spectrum window shows it clearly at 7.6. I can use the B key to manually adjust the bandwidth after it is running with no problem.
What am I missing or doing wrong? It appears that FMP24 sees the command line switch since it acknowledges it at 12.5 but when the actual monitoring starts the BW is getting reset to 7.6. I am using the latest fastlane version...
