  #21 (permalink)
Old 02-20-2017, 6:24 PM
Hello,
Thank you all for the help you give here
I am triying to pair a cc and a vc of a TIII system with 2 dongles for the first time and I need help.
My problem is that the FMP24-VC window opens up but is not showing spectrum,is blank or empty and the title says "VC Idle", the "debug" window shows no errors and says idle, clicking says [R820T] PLL not locked for 9844384HZ!
I reinstalled drivers have tried several TCP port number configurations, fresh DSD+ folder install, VB-cable instead of TCP, changing dongles from USB port, disabling firewalls, reboots, and I don't know what else could I do now.
Here are my files just in case you can see the error, any help is much apreciated, thanks.
FMP24-CC.bat
FMP24 -rc -i1 -o20021 -P42.0 -f179.52415 -a1 -g40 -b12.5
CC.bat
DSDPlus -rc -i20021 -v3 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520 >>CC.log
FMP24-VC.bat
FMP24 -rv -i2 -o27322 -P-1.0
VC.bat
DSDPlus -rv -Pwav -i27322 -v3 -wsl400.210 -wss100.200 -wel172.522 -wcl528.0 >>VC.log
FMP24.cfg
2.4 ; sampling rate (1.0, 2.0 or 2.4)
1024 ; spectrum window width
32 ; FFT size (16k, 32k, 64k)
15 ; spectrum update rate in Hz
5000 -6250 7500 12500 15000 25000 ; step size table; units = Hz; negate default
. ; DSD+ path
.\FMP-FreqList.csv ; primary frequency list CSV path\filename
.\FMP-FreqList2.csv ; auxiliary frequency list CSV path\filename
kilometers ; search units (miles or kilometers)
20 ; search distance
19.7163 -155.6241 ; search origin
I am in windows7 32-bit, have 2 dongles with RTL-SDR chips, and DSD+ Fastlane 2.39
  #22 (permalink)
Old 02-22-2017, 10:23 AM
I think this is not a voice system.... that's why I cannot run FMP24-VC...
  #23 (permalink)
Old 03-05-2017, 6:58 PM
princessthelus's Avatar
Anyone else getting a garbled decoding for Nexedge48 when multiple channels being used at the same time even though you made different priories for talk groups? On the system I am listening to, I have the FD on high and the PD on 50 but when they both are transmitting on different channels the FD gets garbled. I don't know if its processor power or DSD+. I have a super strong signal from the site tower, as it is a few blocks away from me. I also wish I could get DSD+ to run processing power in realtime under Windows 7.
But I am a simple farmer tending to my memes.
  #24 (permalink)
Old 03-05-2017, 10:12 PM
I would suggest posting a screenshot of your setup. DSD+ uses very little CPU resources, assuming you're using FMP24 as the receiver.
"Huhh?? Of COURSE I don't have enough radios, shouldn't that be obvious??! My vehicle has lots of space to put more radios, I certainly do NOT have enough!"
  #25 (permalink)
Old 03-06-2017, 12:07 AM
I doubt it's a problem with processor power. Besides, you can check on that with Windows Task Manager.
You don't say what you're using - a full trunking setup with two dongles? Or is this conventional?
Maybe that's your problem. Are you overloading the receiver? Try turning the gain down.
What does that mean?
  #26 (permalink)
Old 03-06-2017, 4:32 PM
I got it, Turning down the gain helped as the power company is using an unlicensed transmitter on the smart meter on my home and it is overloading the dongles. I also narrowed the bandwidth. I had to play around with the gain and bandwidth in SDR# to get the proper SNR and see how narrow the bitstream was. I used that info to input into FMP. Sounds as good as it can get for NEXEDGE.
  #27 (permalink)
Old 03-06-2017, 5:00 PM
dave3825's Avatar
I would fight that . Read this or google smart meters.
Why Stop Smart Meters? | Stop Smart Meters!
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
  #28 (permalink)
Old 03-06-2017, 7:28 PM
I was wondering and I know this is a little off topic but does these meters fall under FCC part 15A, if so can it cause interference like a part B device cant?
  #29 (permalink)
Old 03-19-2017, 11:46 AM
If the DSD+ devs are still looking at this thread. I would like more Fleetsync and NXDN data interpretation,. When a Call comes through it's only picking up AVL half the time.
  #30 (permalink)
Old 03-24-2017, 4:12 PM
Default We have a big problem
I live in iraq and we don't have the paypal account BUT we have the master card and visa card could any
And you know if you want a copy of fastlane rlease you have to pay by paypal
one please please
Solve this problem
With regards
  #31 (permalink)
Old 03-24-2017, 4:47 PM
Ghstwolf62's Avatar
If I remember right you can pay via Paypal using a credit card without getting an account now.
You might give it a try.
KJ4KFW
One of the few in the world apparently with radios & scanners that actually work like they're supposed to.
  #32 (permalink)
Old 03-25-2017, 11:07 AM
wbigcount's Avatar
What should the bin file look like in DSD+ this is what in mine, and how do you change the options.
 2 3 1 7 %  $  #  " ! %  X
This message is hidden because ------- is on your ignore list. Ahhhh Much better!
  #33 (permalink)
Old 03-26-2017, 1:54 AM
I don't think you can edit the .bin file, as it's some sort of binary blob and not something a text editor can deal with. Since it stores the changes you make in the program, just make your "edits" by doing them in the program, so for example, if you want a window to show up at a certain spot on your screen, just move the window there and when you exit, the new location is saved in the .bin file and the next time you run DSD+, the window shows up where you left it.
  #34 (permalink)
Old 12-15-2017, 3:36 PM
Default Best way to change my mailadress?
Hii @ll
My last received fastlane is DSD+ 2.29. I think gmail block the mails komplete :/
Is there a chance to download the File? Or who can help me to get the last DSD+ version and/or is able to change my mailadress?
Best whishes from north germany and happy and restful holidays.
Thomas
Adress for any answers or the new version please: tom_nopull(at)df2lh.de
  #35 (permalink)
Old 12-15-2017, 6:16 PM
mtindor's Avatar
OH/WV DB Admin
Originally Posted by TomDX View Post
Hii @ll
Thomas
Gmail doesn't block the DSD+ distribution files. That's one reason that platform was chosen for distribution, I believe.
Email dsdplusfastlane@gmail.com -- If you still have access to the Gmail account, email them from that address. If you don't, email them from the new address and tell them what your old address is and explain why you you would like it sent to a different address. I'm sure they will take care of you.
DSDPLus FL 2.39 was sent on or around Feb 11 2017. Search your Gmail account for "DSDPlus 2.39 Fast Lane" or "dsdplusfastlane@gmail.com".
Mike / AA8IA
PSR500/PRO197/BCD436HP/TRX-1
Email: my username @gmail
  #36 (permalink)
Old 12-15-2017, 7:43 PM
Hi Mike mni tnx!
I found the mail with DSDPlus2p29.zap attached in my gMailaccount. The attachment is grayed out and no way to download to my pc. Forwarding this mail is not possible, gMail breaks this with a security warnig :-/ The 2.39 never arrived my gmail... I tried it with an email to dsdplusfastlane@gmail.com a view weeks ago, but didn't get a reply, will try it again today.
'73s Tom
  #37 (permalink)
Old 12-16-2017, 6:31 PM
Default ..
Hi Mike mni tnx!
'73s Tom
Install client mail example LiveMail and configure your account Google..
after read all mail and save file or download (.zap) in your desktop
rename .zap in .zip and decompress file...
finish..
sorry for my bad english...y am Italian
Bye
  #38 (permalink)
Old 12-18-2017, 9:19 AM
Hi mescalero
thanks for the help. In the meantime I got in contact with the DSD+ team. They send me the file again, now with a password on the zap. Google (german) warns about the file, but now it is possible to download the file to my pc
Thanks and season greetings!
Ciao Tom
