Old 04-21-2017, 2:17 PM
Default Trouble with OP25...
I am trying to run scope.py on an Ubuntu machine (16.04.2 32-bit) and I keep receiving this traceback. Can anybody help me understand what it is not happy about? I know that the command instantiation is not perfect, but it doesn't matter what I type in the command line, it shows this error traceback. Thanks.
Casey
Code:
radio@ubuntu-pc:~/op25/op25/gr-op25_repeater/apps$ ./scope.py --args 'airspy' -g 10 -f 853.5375e6 -S 10000000 -T trunk.tsv
linux; GNU C++ version 5.3.1 20151219; Boost_105800; UHD_003.009.002-0-unknown
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.9
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy redpitaya
Using AirSpy NOS v1.0.0-rc10-0-g946184a 2016-09-19, samplerates: 2.5M 10M
gain: name: LNA range: start 0 stop 15 step 1
gain: name: MIX range: start 0 stop 15 step 1
gain: name: IF range: start 0 stop 15 step 1
supported sample rates 2500000-10000000 step 7500000
Using Volk machine: sse4_2_32_orc
  File "./scope.py", line 2759, in <module>
    app = stdgui2.stdapp(p25_rx_block, "APCO P25 Receiver", 3)
  File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 46, in __init__
    wx.App.__init__ (self, redirect=False)
  File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line 8628, in __init__
    self._BootstrapApp()
  File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line 8196, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 49, in OnInit
    frame = stdframe (self.top_block_maker, self.title, self._nstatus)
  File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 76, in __init__
    self.panel = stdpanel (self, self, top_block_maker)
  File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 98, in __init__
    self.top_block = top_block_maker (frame, self, vbox, sys.argv)
  File "./scope.py", line 213, in __init__
    self.__init_gui(frame, panel, vbox)
  File "./scope.py", line 550, in __init_gui
    self.data_scope = datascope_sink_f(self.notebook, samples_per_symbol = 10, num_plots = 100)
  File "./scope.py", line 1479, in __init__
    v_scale, t_scale, None, title), parent, samples_per_symbol=samples_per_symbol, num_plots=num_plots)
  File "./scope.py", line 1601, in __init__
    self.graph = datascope_graph_window (info, self, -1, samples_per_symbol=samples_per_symbol, num_plots=num_plots)
  File "./scope.py", line 1633, in __init__
    self.SetEnableGrid (False)
  File "/usr/lib/python2.7/dist-packages/gnuradio/wxgui/plot.py", line 650, in SetEnableGrid
    if value not in [True,False]:
wx._core.PyAssertionError: C++ assertion "m_window" failed at ../src/gtk/dcclient.cpp(2043) in DoGetSize(): GetSize() doesn't work without window
Old 04-21-2017, 8:25 PM
OP25 generally doesn't run on 16.04. One or two people have modded it to work, but it's non-trivial effort and requires installation of older wx libraries etc. By far the easiest thing to do is run ubuntu 14.04 and installation will be a snap.
Old 04-21-2017, 9:20 PM
Ok. Thats fair enough. I will try this.
Sent from my SM-G930V using Tapatalk
