Old 04-21-2017, 5:58 PM
Default DSD
All, I have a question about using DSD for my tapped scanners. I have a BC 760 XLT and BC 346 XT. My computer is 4.00 gb, intel 2.53 ghz, 32 bit op system windows 7. What do you suggest?
Old 04-21-2017, 7:19 PM
Depends on what you want to listen to. For any trunk-tracking, you need 1 rtl dongle. However, for non-trunked monitoring tapped scanners should work fine, assuming the tap is configured correctly.
"Huhh?? Of COURSE I don't have enough radios, shouldn't that be obvious??! My vehicle has lots of space to put more radios, I certainly do NOT have enough!"
Old 04-21-2017, 8:01 PM
Thanks. I wanted to monitor Chicago Fire Dept and I believe they are conventional.
