Old 06-06-2017, 7:08 PM
Default pro 2020 scanner and Unitrunker 1.0.32.7
Just for something to do today, I hooked my old Realistic Pro 2020 with a discriminator tap and with a cable hooked the scanner up to my line-in in my computer. I started up unitrunker version above and locked my scanner on the control channel to decode Apco 25 signals.
Everything seems to be working, I can see the talk groups and the ID's popping up but I don't get any sound except the control channel even with it in mute. I am using VB Cable to send the signal to DSD 1.74 but no scrolling.
Just wondering if anyone else has done this and if so maybe give me a pointer or two.
Old 06-09-2017, 7:14 PM
Seņor Member
Receiver configuration here:
UniTrunker | Receivers
Setting up voice following here:
UniTrunker | Voice Following
Old 06-12-2017, 7:11 PM
So with the setup using signal receiver, I take it that I will only be able to decode the Target, as nothing comes up with the Source.?
Old 06-19-2017, 2:32 PM
Need some help this is getting frustrating, still no sound, everything is working just like if I was using a singal RTL-SDR just no sound.
I have used the same sound setup using SDR Sharp, VB Cable to DSD1.74 and that works good, just not with a discriminator tap. Any ideas, I have used the instructions in the above link, thanks unitrunker, but no joy. Any help would be appreciated.
MB
