DSDPlus switch info
D
DaveNF2G
Guest
The current DSDPLUS.TXT file, dated 7/14/2018 for FL users, does not list the switch for enabling Fusion decoding.
Is it -ff?
cg
Connecticut
If you run that in a DSDPlus batch file, only Fusion starts. I would say that is a good bet you are correct.
chris
slicerwizard
Toronto, Ontario
Is it -ff?
-fa Auto-detect all protocols / frame types except dPMR [-fa]
You don't need any switches to enable Fusion decoding. The -h help display shows that -fa (autodetect everything but dPMR) is the default.
D
DaveNF2G
Guest
Enabling a single protocol when the desired decoding is known reduces the falsing.
