Old 09-01-2018, 6:39 PM
Default How to setup Hytera XPT in DSD+
Has anyone set up a Hytera XPT system in DSD+? If so, what protocol did you use? I know it would not be D-star, Nexedge 48 or 96, cap+, con+, P25, or provoice. That just leaves IDAS, dpmr, DMR, or TIII. Any help would be appreciated. I'm not near the site to receive it from home, but go near it on occasion and would like to use DSD+ to find the LCN's, since the LCN finder on my 436 and SDA100 give me different readings everytime I do it. Thanks.
Bill (KH6SZ)
BCD436HP, TRX-1, Legacy Updated Pro-668, Pro-528, Pro-51, Pro-38. 4 RTL-SDR USB Dongles.
HTX-202, MD-380, 3 Baufeng UV-5R
Old 09-02-2018, 2:53 AM
Smile
At present DSD+ does not decode networks on XPT enabled systems. It is arguably said whether it's parent is in fact Tier III, but the setup is more or less equivalent to a Mototrbo capacity plus system. Your not alone as I happen to monitor a couple XPT systems and still no sign that they are linked up. Hope this helps my friend.
Cheers
Old 09-02-2018, 7:03 AM
cg cg is offline
The voice is decoder with DMR in DSDPlus but the issue is with trunktracking a site. If you are using the Fast Lane, you can create a system ID for the site and scan the frequencies that way.
chris
