Old 10-09-2018, 1:56 PM
Default DSD help
I am trying to monitor this but get errors. A screen shot is attached of the errors. Do I have a setting wrong? Thanks.
Old 10-09-2018, 3:42 PM
What are you using to send the data to DSD?
That is to say, what software are you using to
tune in the frequency? SDR#, HDSDR, etc?
When I used SDRsharp, I had a helluva time tuning
in for DSD. It was tedious but you need to fool with the
gain, turn off all filtering, play with volume, until you get
it right
Old 10-09-2018, 4:15 PM
What operating system?
If windows have you tried DSD+?
Old 10-09-2018, 10:04 PM
That is DSD+.
Old 10-10-2018, 7:41 AM
I have a tapped radio. It decodes for other departments.
Old 10-10-2018, 9:38 AM
If you upload a raw audio recording somewhere, we could offer useful advice.
Old 10-10-2018, 1:22 PM
Originally Posted by slicerwizard View Post
That is DSD+.
Ooops, I was fooled by the thread title :-)
Old 10-10-2018, 3:43 PM
Close your squelch...its wayyy open
Old 10-10-2018, 6:36 PM
Do you need the discriminator audio or from the earphone jack? This unknown department is not on alot and the CW ID is to fast for me.
Old 10-10-2018, 8:24 PM
mtindor's Avatar
OH/WV DB Admin
Discriminator audio is a must - nothing less for digital signals. Just record a raw audio file in DSDPlus by starting up DSDPLus and pressing 'R' to record raw audio. Record it for a minute or two. Then press "R" again to stop the recording of raw audio.
Find that raw audio file in your DSDPlus folder -- In case you have more than one raw audio file already, it will be the the latest timestamp. It'll look something like this:
DSDPlus-Raw-Input_2018-10-05@000444.wav
Make it available somewhere that you can provide a link to so that it can be downloaded by others.
Old 10-11-2018, 12:41 AM
Because squelch has no effect on discriminator audio.
Old 10-11-2018, 8:22 AM
Thanks for the help. The signal is weak today. The frequency is 151.67. I have not found anything in the FCC database. I'm in Trumbull County Ohio. Have checked in PA also since I'm not far from the boarder.
