| Washington Radio Discussion Forum Forum for discussing Radio Information in the State of Washington. |
01-02-2012, 01:43 AM
800mhz I tac frequencies vs U-tac and V-tac?
800mhz I tac frequencies are used here in Washington state. I haven't tried any of the U tac or V tac frequencies. I am programming my Radio shack Pro 163 with frequencies and trunked systems I don't have in my other radios, specifically my Radio shack Pro164 and GRE PSR 500.
Primary scanner GRE PSR 500 secondary Pro163,Pro 164 Pro96
01-02-2012, 05:51 PM
I'm not sure if you're asking a question.
I've used I-tac before, but I've never used U or V-tac. Since the implementation of 800MHz trunked radios most places don't even have VHF or UHF equipment. This might change when everyone buys the new, fancy all-mode Motorola radios.
01-02-2012, 05:58 PM
Well, I was just wondering if the other VHF and UHF frequencies were used here?
01-02-2012, 09:44 PM
My vote would be for no. This is the first time I've even heard of them.
01-02-2012, 11:13 PM
I've never heard any of the UHF ones used, but the VHF ones are used, mostly in the SW Washington and Eastern Washington areas. I've heard V-TAC 14 (159.4725) being used as a LE chat channel, and V-TAC 11 (151.1375) used on a major fire.
01-03-2012, 08:28 AM
A search of the FCC database will show who is licensed to use them.
01-03-2012, 08:57 AM
Not necessarily. Anybody with a public saftety conventional or trunked license is licensed by rule to operate mobile stations on the national interoperability channels.
I don't know if this applies in WA but several other states have interoperability agreements that allow public safety users to operate under state licenses.
Tom
01-05-2012, 04:47 PM
A search of the two freqs. given shows that each has 13 licenses in WA, including a hospital, several counties and cities.
01-06-2012, 05:54 AM
Each state does vary on how they plan to handle Interop as well as the licenseing issues, so it will ultimately be tough to narrow down site locations [if any are permenant] vs Temp CP set-ups.
I would plug them in anyway [any new scanner has plenty of room]
01-06-2012, 08:31 AM
I should have added that searching for licenses will not tell you all of the users that you might hear on the interop channels.
Tom
01-06-2012, 04:44 PM
True. Perhaps you can tell the OP another way to find out who he might hear on those freqs. I believe that was his original question.
