Originally Posted by lifesavin
I have acquired a PRO-164 scanner. Does anybody know how to program this thing? I live up in the Seattle area so I need to be able to program the trunked channels. Having a little difficulty figuring out this scanner.
First thing you should do is download the Manual.
Here are the steps for the Portland system. Just put in the correct control channels for the system you want.
The Pro-164 needs only the four control channels for each system to hear the entire system. Use one bank for each system.
First bank will be for the PORTLAND system.
(Each bank has 5 sub-banks, each holding 30 Talk Group IDs.).
The first step is to enter the control channel freqs.
1. Press PGM -> TRUNK -> FUNC, then use the arrows to select a bank.
2. Press MODE, select MOT.
3. Press PGM, select channel number. (use arrows to change channels).
4. Enter the first freq. 858.7125 -> ENT
5. Press MODE until MOT appears -> ENT (MOT will apply to next 3 freqs.).
6. Enter next freq. 858.7375 -> ENT.
7. Enter next freq. 859.2625 -> ENT.
8. Enter the last freq. 859.4625 -> ENT.
9. Press SCAN.
Now it will start "trunking".
There are two trunking modes, OPEN and CLOSED.
In OPEN mode you will hear ALL active Talk Groups.
In CLOSED mode you will hear only the TGs you enter into the sub-banks.
To program the sub-banks.
1. MAN -> PGM -> TRUNK.
2. FUNC - arrow to select bank.
3. Press MODE to select MOT.
4. Press TRUNK to select sub-bank.
5. Enter a Talk Group ID (2 to 5 numbers) -> ENT.
6. Enter then next ID -> ENT.
7. When all IDs have been entered, press SCAN.
