Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Washington Radio Discussion Forum
Washington Radio Discussion Forum - Forum for discussing Radio Information in the State of Washington.
  #281 (permalink)
Old 08-12-2014, 5:57 AM
lowboy654's Avatar
DB Admin Member
Welcome aboard
If you choose not to decide, you still have made a choice.
Ken
Data Admin
lowboy654@radioreference.com
  #282 (permalink)
Old 08-12-2014, 5:41 PM
Cool
Originally Posted by SkyOtaku View Post
Equipment:
Uniden BCD536HP
Radio Shack 20-032 Magnet Mount
(antenna on metal roofed home) have another one on my SUV
Lee, dump the magnet mounts. You can thank me later.
  #283 (permalink)
Old 08-12-2014, 8:00 PM
Any idea for a replacement? I can see a replacement for the base mount, that was a temporary replacement for the stock antenna due to a metal roof. What would you recommend for the mobile replacement? I don't have any problem picking up 800mhz p25 trunked with either system. I don't have any P25 phase II systems within 200 miles of my location. Most signals in my area are either analog conventional/trunked or P25 Phase I conventional.
  #284 (permalink)
Old 08-12-2014, 8:11 PM
Cool
Lee, I was being somewhat fatalistic but in reality, you'll get better performance using a NMO mount. Also, it just looks better. Of course, this means drilling a hole into your trunk lid or roof. Center of roof is considered ideal but at 700/800 Mhz a trunk lid is fine too.
Mount: MB240: 3/4" Hole Brass NMO Mount with 17' LMR240 Cable
You'll need to buy a BNC connector kit for this mount.
Antenna: ABSCANC - Antenex Scanner Antenna (150/450/800 MHz, Receive only Gain, Black)
Alternate Antenna: QWB450 - Antenex Quarterwave Antenna (450-470MHz, Unity Gain, Black)
I switch scanner antennas when I have to go into parking garages, etc. The Laird scanner antenna is 19" so it's just a tad tall for my Durango. It's a great scanner antenna though. The UHF antenna does fine when I need to go small.
Obviously, not everyone can drill holes into their vehicles for various reasons. Some radio shops can install the antenna for you for a very reasonable cost. It only takes about 30 minutes when done properly.
  #285 (permalink)
Old 08-12-2014, 8:45 PM
Thanks for the info but that is a little bit extreme for me as I use that antenna on multiple vehicles. It seems to work fine for what I use it for at least. Its just a longer version of the one you linked to. I attached a pic of it. It may be a little unsightly but for around here that's normal being in a small farming community in the boonies
  #286 (permalink)
Old 08-24-2014, 11:04 PM
Hello everybody,
I've moved to Redmond, WA. I'm using an old Bearcat BC895XLT. I'm only using the whip antenna that came with it, so I'm not picking up much in my 3rd floor apartment up on the hill.
When I have the dough to get an actual home here, I'll start upgrading my gear. Work keeps me busy, and away from the airwaves.
Just wanted to drop in and say hello. I've been away for quite a while.
Cheers!
  #287 (permalink)
Old 08-26-2014, 9:20 PM
Talking New Base Antenna System
I finally got my base antenna up and working. Here is what I used:
D130NJ Diamond Super Discone Antenna
LMR-400 Coax Cable, 75', N Male & BNC Male
Attached is a pic of the antenna at the end of a 22ft mast. Already seeing great improvement in reception. I never would have gotten what I did if it wasn't for the discussions in this forum.
Lee Kanzler
  #288 (permalink)
Old 08-26-2014, 9:33 PM
Cool
I finally got my base antenna up and working. Attached is a pic of the antenna at the end of a 22ft mast. Already seeing great improvement in reception. I never would have gotten what I did if it wasn't for the discussions in this forum.
Looks good Lee! Just out of curiosity what did you use for a mast? I'd love to find something cheap, manageable that's around 20ft. I heard of some supply warehouses selling cheap EMT conduit in 20ft and 40ft lengths but getting it home would be a chore.
BTW, the Diamond is a good antenna. I have the R/S version (which is an exact copy) and it's still going strong after 13+ years up on the roof despite many snow, rain and wind storms. It's on the corner of the house, so it's not exactly vulnerable like yours but if mine is any indication you should haven't any problems.
For gain, you may want to consider one of DPD antennas such as the LP model:
http://dpdproductions.com/page_scanner.html#uhflp
You can use the same mast. Just have to add another run of coax. It's great for picking up trunking sites at long distance especially since you have some height on your mast.
Cheers!
  #289 (permalink)
Old 09-20-2014, 2:20 PM
dpm3's Avatar
Not sure if this is the thread to post this inquiry, but I will give it a shot. I've "recently" (15 months or so) returned to the Seattle/Tacoma are after spending 15 years in the St. Louis area. I'm attempting to better understand the utilization of certain talk groups in the Seattle/King County Public Safety system; specifically the PSOPS and ERT talk groups. Are these talk groups available for use by any of the various municipalities participating in the system? Are certain groups assigned to certain agencies? If so, which ones use which group? What is the difference in use between PSOPS and ERT- and what does ERT stand for? How does the use of these talk groups differ from the TAC talkgroups? I'm trying to organize the various system talk groups into scan lists on my GRE PSR-500 in such a way as to avoid scanning ALL the ERT/PSOP/TAC groups in every scan list. Another question is in regard to the use of the Valley NARC talkgroups. Is this King County PD only or do various municipalities use it as well? Thanks in advance for your insight and assistance.
  #290 (permalink)
Old 10-14-2014, 10:05 PM
Howdy! Just recently discovered these forums. Not sure how I missed them all these years. I am in Seattle and usually listen in to Police and Fire radios for most places in the NW of King County. Currently using a BC246, but just upgraded to a BCT15X, but having a hell of time programing it. Looking forward to trying to contribute more around here!
  #291 (permalink)
Old 11-14-2014, 12:21 PM
lowboy654's Avatar
DB Admin Member
Sorry for the slow reply welcome aboard.
Ken
Data Admin
  #292 (permalink)
Old 04-15-2015, 3:35 PM
Hey everyone first time posting to the forum, I listen to south sound 911, tacoma/puyallup
and a few other county's/agencies
125at
396xt
Pro 668
  #293 (permalink)
Old 04-18-2015, 2:21 PM
lowboy654's Avatar
DB Admin Member
125at
396xt
Pro 668
Welcome aboard "Robert" sorry for the slow reply, due to a death in my family I have taken sometime off from here.Its alway nice to see new folks around here.
Ken
Data Admin
  #294 (permalink)
Old 06-03-2015, 1:37 PM
good day one and all, here is a question for you..........i have been having issues getting both the Spokane, Valley fire department and the Spokane city fire departments primary channels.......have they gone to encrypted?
  #295 (permalink)
Old 06-03-2015, 5:01 PM
Cool
You do understand they moved to P25 digital?
Spokane Regional Emergency Communications System Trunking System, Spokane, Washington - Scanner Frequencies
  #296 (permalink)
Old 06-03-2015, 5:19 PM
ended up switching from SCOOP to the SIMULCAST frequencies
  #297 (permalink)
Old 06-03-2015, 11:42 PM
Cool
Why not just program in all of the sites. Let the scanner do the work for you.
  #298 (permalink)
Old 07-07-2015, 12:16 AM
jondeaux's Avatar
Well, Hello everyone!
I have been an avid Scanner listener probably since like the 7th grade. Started on some old Radio Shack 10 channel 512mhz scanner.
Now days I run 2 while at home. BCD396XT with a RS 800mhz antenna and a BCD436HP with a RS 800mhz antenna. I also have a BCD296T with apco card installed. Has some minor cosmetics damages and could be willing to part with it if anyone needs/wants an older scanner. If the 436HP came with an option to charge battery while in use I would use that while at home, but alas it doesnt. But, while on the road the 436HP is with me.
I live and work in the Seattle metro area. Mostly monitor Seattle Police. Often thought about applying for just SPD feed. I dont do the fire stuff... Too noisy here in the city with aid calls etc. SPD usually gets dispatched to fire's for traffic control. So I dont usually miss the actual structure fire calls.
I do retail security, prior service military / combat veteran.
  #299 (permalink)
Old 07-26-2015, 12:11 PM
Hi everyone! I joined last week but Have been an active scanner listener for many decades. I live in Port Angeles and have for almost 25 years now. I have 5 scanners on top of several HAM radios. A PRO-84, 2026, 2004, 163 and 433.
  #300 (permalink)
Old 09-27-2015, 12:24 AM
South Pend Oreille county here. I have a HP-2 and a Bearcat 350A (might still be good for Stevens county). Recently gave away a Pro-95 to a friend in Stevens county which is still analog. Ordered a few cheap SDRs to play with.
Not listening to too much yet.. working on antennas. Wanting to be hearing Law/EMS/Fire with a dash of Military and Forestry/Park stuff thrown in. So far a cheap suction cup antenna has outpreformed the factory one.
Anyone near Spokane/Newport area willing to be hired to get an old discone that is currently on the roof re-coaxed? I'm disabled so ladders and roof running are just not in my future.
I also would be willing to trade an AEA Isopole 2m and/or a Shakespeare Big Stick to do it proper (which are also on the roof)?
Cheers
Linda
Tags
sticky
