Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > West Virginia Radio Discussion Forum
West Virginia Radio Discussion Forum - Forum for discussing Radio Information in the State of West Virginia.
  #1101 (permalink)
Old 03-18-2017, 9:02 PM
Originally Posted by n8jsw View Post
The only three right now in the area are the Ohio county simelcast moundsville and st.joesph towers in norther wv
How far down into the state will these cover? I'm looking to swing the corner of the state in towards Monongalia County as well.
  #1102 (permalink)
Old 03-18-2017, 10:45 PM
n8jsw's Avatar
Not real sure how far down st.joesph will cover but look in the database and the towers are in there for future south
N8JSW
Icom Ic-2350H, Uniden BCD396XT,Uniden 996P2
  #1103 (permalink)
Old 03-19-2017, 8:42 AM
jonwienke's Avatar
Originally Posted by SurgePGH View Post
I am looking for some tower names from the database as they relate to monitoring in a handful of counties. I mainly work in Fayette, Greene, Westmoreland and Allegheny counties in PA. I do find that I wind up in the West Virginia counties that border these areas and also do work in these WV areas. I am looking to program the SIRN system into my scanner but only want to put the relevant sites in.
Just put the whole system in with Sentinel. There's no good reason not to. Location Control will automatically lock out sites out of range. Get the GPS puck and connect it to the scanner, and let the scanner do its thing. It's a lot smoother in most cases than manually toggling things on and off. The extra sites don't slow the scanner down when they aren't being scanned.
  #1104 (permalink)
Old 03-19-2017, 8:05 PM
Im not picking up anything from the northern panhandle. I live in wheeling. I've tried different antenna locations and antennas . At a loss. I've reprogrammed my scanner to no avail. I am using a b996xt.
  #1105 (permalink)
Old 03-19-2017, 8:21 PM
n8jsw's Avatar
Well first what all you trying to pick up and second you might be have a issue with the simelcast issue
N8JSW
  #1106 (permalink)
Old 03-19-2017, 8:51 PM
Fire/Em's police . I did hear vgvfd Em's to hospital but that was it. What is the simelcast issue and how to fix. I used to get everything just wheeling and of were garbled at times.
  #1107 (permalink)
Old 03-19-2017, 8:57 PM
n8jsw's Avatar
Well you could use a beam or the radio-800mhz for a handheld but make sure also that the banks for fire and ems didn't get turned off but I have a 536 and a psr-800 and hear them perfect and downtown also
N8JSW
  #1108 (permalink)
Old 03-20-2017, 1:50 PM
A beam? Would a disconnect do any better.? I have a short rubber ducky run to the upstairs with no help.
  #1109 (permalink)
Old 03-20-2017, 2:59 PM
jonwienke's Avatar
You're talking about 15-40 miles over hilly terrain. An indoor antenna is going to have difficulty getting that kind of reception. You're going to need an outdoor antenna with some elevation to get good reception.
  #1110 (permalink)
Old 03-21-2017, 2:56 PM
Would a discone antenna in the attic workż
  #1111 (permalink)
Old 03-24-2017, 2:30 AM
Brooke and hancock are not on sirn at this time. there are no towers north of ohio county. There is possibility of one being built in beaver county pa to covers those two counties.
  #1112 (permalink)
Old 03-25-2017, 4:23 AM
firemantom26's Avatar
Weirton Area has a tower in place but hasn't been turned on for Brooke County.
Tom
BCD436HP
BCD536HP
HOMEPATROL 2
  #1113 (permalink)
Old 03-25-2017, 9:06 AM
mtindor's Avatar
OH/WV DB Admin
From the SIRN newsletter:
Weirton Tower
  • No LOC’s are coming back to Hancock or Brooke Counties; no response from Pa. agencies on LOCs.
  • Lauttamus Communications has frequencies available.
  • Local law enforcement (i.e. Hancock and Brooke Counties) have P-25 radios that they cannot use. They are considering meeting with local Senators and Delegates to address the matter.
  • Frequencies were licensed for a simulcast site however there was concern of overloading the system.
  • Business frequencies from the former Weirton Steel are no longer available.
  • Beaver County tower; agreements in place and waiting on installation of equipment.
  • Hancock and Brooke County public safety agencies requesting to meet with the SWIC and Project Manager about the Weirton Tower.
Mike / AA8IA
PSR800/PRO197/BCD436HP/BCD536HP
  #1114 (permalink)
Old 03-27-2017, 11:01 AM
Default GPS
I bought the ARC536 S/W and have been trying to learn that. When I change the location control from Circle to Rectangle it is missing the extra Lat Long fields. I'm really lost now. LOL I have been tinkering with Sentinel for the past three days and am starting to get a grip on it. I am trying to get my rectangles to keep a tight boundry on most counties so that I can avoid too much radio traffic while travelling. So I am now asking myself.... What does the ARC software do that Sentinel does NOT do?
  #1115 (permalink)
Old 04-06-2017, 6:46 PM
RadioDitch's Avatar
Is all of Morgan County now on the system, including Paw Paw? Or are there still some conventional frequencies in regular use? I know I can't imagine Paw Paw's LTR still being on the air.
QTH: America.
Gratuitous Radio Ownership Listing Here.
Be a man. Drill it! Support Hams Against Magnetic Mounts.
Hard Truth: Live Streams Are A Threat To Scanning
  #1116 (permalink)
Old 04-06-2017, 7:52 PM
mike_s104's Avatar
I monitor the Hampshire Co. Ridge site. I regularly hear FD, EMS and the sheriff's office but I can't answer if they use any analog freqs.
Sent from my SM-G930V using Tapatalk
  #1117 (permalink)
Old 04-16-2017, 7:00 PM
does anyone have the band split on a codeplug for the state system? I was just wondering how the band split would be.
  #1118 (permalink)
Old 04-16-2017, 9:55 PM
mtindor's Avatar
OH/WV DB Admin
If you go to www.sirn.wv.gov and then click on Information --> Downloads and read one of the newsletters. somewhere in the newsletters they usually have some programming info.
Mike / AA8IA
  #1119 (permalink)
Old 04-16-2017, 10:32 PM
jonwienke's Avatar
Morgan County mostly uses SIRN. I've never heard much on their analog freqs that wasn't a simulcast of SIRN traffic.
  #1120 (permalink)
Old 04-17-2017, 8:08 PM
RadioDitch's Avatar
Thanks Jon. Noticed that the last week. Been away for a while, but back in the area now.
QTH: America.
Tags
sticky
