Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > West Virginia Radio Discussion Forum
West Virginia Radio Discussion Forum - Forum for discussing Radio Information in the State of West Virginia.
  #1301 (permalink)
Old 12-04-2018, 2:53 PM
OH, PA, WV Regional Admin
Originally Posted by mule1075 View Post
Here is the bandplan if anyone needs it.
It still seems like 3.1 isn't sending a bandplan.
Here is the bandplan I've monitored with DSD+ FL:
Code:
Network: BEE00.170  ; WV SIRN
  Bandplan #0:   Base=851.00625   Offset=-45     Spacing=6.25  BW=12.5
  Bandplan #1:   Base=762.00625   Offset=+30     Spacing=6.25  BW=12.5
  Bandplan #2:   Base=453.025     Offset=+5      Spacing=12.5  BW=12.5
  Bandplan #3:   Base=450.        Offset=+5      Spacing=6.25  BW=12.5
  Bandplan #4:   Base=400.        Offset=+9      Spacing=6.25  BW=12.5
    Site: 3.1    NAC=170    ; Ohio County
    Neighbor: BEE00.170-1.2      ; Morgantown
    Neighbor: BEE00.170-1.6      ; Fairview
    Neighbor: BEE00.170-3.2      ; Moundsville
    Neighbor: BEE00.170-3.3      ; St. Joeseph
    Neighbor: BEE00.170-3.6      ; Beaver Falls
    Channel 2-11:     453.1625              VOICE
    Channel 2-12:     453.175               VOICE
    Channel 2-23:     453.3125         SCC
    Channel 2-25:     453.3375     CC
    Channel 2-33:     453.4375         SCC
    Channel 2-43:     453.5625              VOICE  DATA
    Channel 2-581:    460.2875              VOICE
Shawn KB8UDE
BCD436HP, BCD996XT, Airspy/SpyVerter, NESDR SMArt
Motorola XPR 7550/4550, XTS/XTL 5000, XTS 2500,
Quantar VHF, XPR 8400 UHF, MSF 5000 900MHz
Uniden Washington, RCI-2950, Yaesu FT-897D
  #1302 (permalink)
Old 12-06-2018, 9:08 AM
dintimid8or's Avatar
Originally Posted by redbeard View Post
TAC stands for 'tactical' and that is just a name given to channels needed 'in the moment' vs regualr dispatch or other designated talkgroups. As it is just a name and the talkgroup is just a talkgroup, there is no reason to assume it is or is not encrypted. Typically law enforcement are the only ones to encrypt. Sometimes they encrypt everything, sometimes only when the need arises for security. There are exceptions of course such as Fire/EMS agencies that also use encryption but they typically do not.
As others have said, reference the database for the tactical talkgroups for your area and you can program your device with the proper talkgroup number. A quick look shows 9 TAC channels for Berkeley, and only the arson investigation channel seems to use encryption.
We refer to them as Talk Around Channels (TAC). We are supposed to use these channels to refrain from interfering with emergency traffic.
  #1303 (permalink)
Old 12-08-2018, 1:30 AM
As long as everyone knows what and how to use them you can call them whatever you want. But in the parlance of the industry 'talkaround' (also called 'direct') typically refers to a conventional repeater system, where instead of using the repeater normally in a duplex fashion you instead use only the output frequency for simplex. This way anyone still on the repeater channel will hear you if in range, but you don't activate the repeater thereby 'talking around' it.
If your Tac channels are on a trunked system, you aren't talking around anything you just switched to a different talkgroup freeing up a dispatch channel for other calls.
Also on a trunked system, due to the design and operation, any simplex channels used as talkaround are typically separately licensed simplex frequencies rather than any of the trunked repeater output frequencies.
Shawn KB8UDE
  #1304 (permalink)
Old 12-09-2018, 8:56 PM
Default OC Bandplan
Is there any likelihood that Ohio County will ever send their band plan for their simulcast system or will it be like encryption for many of us who canít receive them?
  #1305 (permalink)
Old 12-09-2018, 9:26 PM
mule1075's Avatar
Load this file in sentinel and write it to your hp-1 ans see if it solves the problem.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
Tags
sticky
