What is the best or most used tracking program ? Which gives the most information ?
What are you wanting to track? Trunked system activity?
Unitrunker (
Unitrunker )
Pro96Com (
Pro96Com - Control channel decoder for P25 Trunked Radio Systems )
Trunk88 (
Index of /~phoenix/wap/TRUNK88 )
Unitrunker and Trunk88 are good for Motorola Type II systems. Pro96Com and Unitrunker are good for P25 systems. Unitrunker handles multiple types of trunking systems, whereas Trunk88 handles one (Moto Type II) and Pro96Com handles one (P25).
My personal thoughts are that if you want to monitor SIRN, Pro96Com is the easiest/best, but it requires that you have a supported scanner that can send the data over the serial / usb cable. Unitrunker and Trunk88 work with PC/IF data from the scanner via cable as well as discriminator taps.
I always use Pro96Com to monitor SIRN. I use Unitrunker to monitor everything else.
As far as actually trunk tracking (by using multiple receivers with the program), Unitrunker supports that; Pro96Com does not. Trunk88 may.
