I have to say sorry to Whistler.
But that does not 100% mean that they should not put a bit more work into their front end design before the next new models come out. Not the 1088 or 1098, the next batch of new models.
My PSR800 is fine .. cause it always just sits with a rubber duck on it.
I have been having issues with in particular my WS-1095 and well this is a story for the people here.
It is all about ... our scanners.
The issue .. is that my 1095 is very very much a boat anchor right now. It is well .. virtually deaf on all bands except 800 MHz. Sometimes too much sensitivity and not enough in the selectivity department .. can have bad consequences.
But I always read about people here wishing their scanners were more sensitive. Be careful what you wish for. The issue is almost never a lack of sensitivity.
That is where it gets interesting. I have used a FM trap filter in an attempt to lessen the issues that the scanner is having. But the biggest offender was not the FM stations. But .. they did contribute for sure.
So my 1095 had still very big issues compared to my Uniden HomePatrol.
Well .. today I found out why.
It is being totally swamped by an offending signal. It is from a taxi service (the signal is the data for their computers) with a TX site about 2.5 blocks from here.
Well about a month ago I did a signal sweep of the whole commercial bands from 88 to 900 MHz from my location. Well it came in very handy ..
Using a variable VHF notch filter I was able to determine that the offender that was causing all the issues was indeed on the VHF band.
So programming the top 100 strongest signals into my HP1E I very quickly found the offender, two frequencies very close together. A bit of listening to the intermod .. and bingo. (yes .. it was even giving my HP1E a fit, complete with intermod on some frequencies) It was just easier to id the issue on my HP as it was not impacted as much as the 1095.
The moral .. maybe the issues that you are having is not your scanner, it is just doing its job but may be getting totally swamped. Yes .. unless you do your homework, you will likely never know the real reason.
The signal btw was -4 dBm .. so about 70 over s9 on my dongle. Because our scanner do not have real s-meters, they kinda suck at determining what the signal really is.
Oh please Whistler .. can we have real digital dBm meters (or similar) on our scanners ? Or at least something other than some useless bars.
Me .. I am thinking about tapping my 1095 just to add a digital s-meter, no bars for me.
I will be zapping those 2 frequencies very soon .. and my Whistler scanner will be able to do its job hopefully with much delight.
I just think of a fellow RR member here that had similar issues with his 1095 and returned 2 of them, believing they had issues. He returned to using his Uniden scanners.
So .. if you live in the country with no nearby transmitters, you will be fine and likely not have any issues with your scanner.
But if you live in the big city with lots of sites, there may be that one that is just wiping your scanner out. Unless you do some research and snooping around .. you likely will blame your scanner for what really is pretty unavoidable in such conditions.
I still maintain that how our scanners perform is directly related to where you are using them and the signals present.
If you want to read about how scanners perform under stress .. read this thread. Shameless plug .. yes I was involved in the testing.
http://forums.radioreference.com/general-scanning-discussion/319013-uniden-whistler-scanner-selectivity-shootout.html
And .. to be fair, sensitivity test results. Yes I know .. need to do some of the newer scanners. It is on the list.
http://forums.radioreference.com/gre-scanners/309168-whistler-1080-psr800-psr500-bcd436hp-shootout.html
But please .. if you want to talk about LSM, not here. This is mostly a pro Whistler thread.
