+1 on WIN500. I can program my GRE500-pattern scanners manually...but doing the whole thing that way would probably send me to the insane asylum. The software and cable are well worth the cost.:wink:
Not to make it too easy for ya but -- I created a Win500 file for Greenbrier ... If you still need help after downloading a 30 day trial copy of Win500 and playing with it and the programming cable, let me know...
Hi, you seem to be knowledgeable...do you know offhand if the WS1040 will accept a clone from a PRO651? I suspect yes but would like to be sure before I buy one...thanks!
I believe the answer is yes. Generally, they are all the same radio.
I have a RS PRO-651 and a GRE PSR-500 and they clone back and forth. The WS1040 is the Whistler version of the same radio(s) so I expect that should work as well.
