Here are my questions. I am really needing assistance
1) If a DMR system is already on the SD card, is it necessary to self-program it....?
By that I mean...Couldn't you simply go to "Browse Library" then enter your state / county
and the DMR system you are wishing to hear....and then assign it to a scanlist?
(Instead of manual programming (ie) using the Program Menu to add a new system and its frequencies.
2) Posted below is the DMR system I wish to scan - But am having difficulty (I am not receiving the system)
Posted below is the system I am wanting to program:
_____________________________________________________________
System Name: River Spirit Casino
County: Tulsa
System Type: DMR Motorola Capacity Plus Single Site (TRBO)
System Voice: DMR
System Frequencies
Site Name
001 (1) casino 01 451.300 03 452.000 05 452.850
System Talkgroups
DEC Mode Alpha Tag Description
100 T Security Casino Security
103 T Shuttles Parking Lot Shuttle Vans
Given this data above, here is the process I completed:
1. I tried to simply import the system from the --library-- and assign it to a scanlist.
(The system is in the library and already on the SD card)
That did not work: Unable to listen to the system
So I tried to manually program the system:
Here are the steps I followed:
A. Selected Program Menu
B. Selected Add System
C. Selected DMR
I am now in the --Add System- menu
I assume now I select "Edit Sites"
D. I then selected "Add New"
E. I then selected "Frequencies"
Looking at the system I posted above, here is how I entered the frequencies (See Above)
01: 451.3000
03: 452.0000
05: 452.8500
I then assigned the two talkgroups: 100 and 103
I then imported this to a scanlist and am not hearing anything
______________________________________________________________
** Here is the interesting part:
If I complete a "Limit Search" and the above-frequencies come up, I --can hear-- the DMR communications
from this system on the individual frequencies, respectively.
Of course, however, there is discontinuity in listening to the complete conversations.
This alerts me that I am close enough to the site to receive it, and the scanner can encode it,
but when I attempt to import the system from the (1) Library --or-- (2) Self Program it and assign it to a scanlist... I hear --Nothing--
__________________________________________________________________
Is there anyone in this forum that could provide feedback as to what I might be doing incorrectly.
Posting here or giving me a private message would be sincerely appreciated.
I am really needing assistance......
Thanks!
County: Tulsa
System Voice: DMR
System Frequencies
Site Name
System Talkgroups
C. Selected DMR
01: 451.3000
03: 452.0000
05: 452.8500
Thanks!
