Old 06-05-2017, 3:16 PM
MedicDavid78's Avatar
Question TRX-2 and Clock
Hello all... Just got my new TRX-2 today, for the most part I understand how to program it using the PC cable. 1 thing I can't figure out is the clock, when you power it down I got the clock to display, but it shows 24-hour time, is there a way to change it to 12-hour time? Thanks! Love this little thing, the P25 digital decode is far superior than my Uniden 536HP...
David - WRAX515
Radios: XTS5000, XTL5000, XTS2500, HT1250, Baofeng UV-5R, Anytone D868, CS-800D
Scanners: Uniden BCD536HP, Uniden BC246T
Pagers: Unication G1, Minitor 5
Old 06-06-2017, 5:20 AM
DJ11DLN's Avatar
No, it will only display in 24-hour format. Maybe Whistler will address this in a future update but for now we're stuck with it.
If it's like the clock in my WS-1098, it won't keep reliable time anyway...mine was off by more than 10 minutes in a month. I don't even let it display any more. But that's fine, I bought a scanner, not a clock, LOL.
If it looks stupid but it works...it ain't stupid.
Old 06-06-2017, 7:23 AM
Well now that just sucks! Not everybody uses military time....... Whistler, you seeing this??
David - WRAX515
Old 03-13-2018, 2:56 AM
Can someone help me with an issue I have with my TRX-2 not keeping time?
I use my TRX-2 in my truck and have power to the radio at all times so that the clock is displayed. However, I set the clock and then after several weeks it is way off. Is this a recall item or what is the fix? I do sometimes unplug the power in my truck but only overnight and I understood that there was a backup battery in the TRX-2. Any help or direction would be greatly appreciated. I tried to look at all the threads and forums but could not find anything.
Dana
Old 03-13-2018, 5:41 AM
It would create problems with sorting and naming of log files and such. If it's all digits it's much easier than to also handle am and pm letters in filenames and when sorting and other problems we might not realize at a quick glance.
/Ubbe
Old 03-13-2018, 10:45 PM
dkf435's Avatar
All the dispatching around here uses 24 hour time format, how would you match the logs with the recorded traffic.
David
AR3000,5000,8000,8200,8600,SDU5000,5500,ARD25R1,10 ,20,71,72,75,7000,7100,8500,PC/R100,1000,2500 PSR500,600,800,PRO668,2035,96,106,BC760,796,996T,9 96XT,396T,396XT,HP1,HP2,436HP,536HP,WH-TRX1
Old 03-18-2018, 3:41 AM
Whatever they use as the clock circuit in their radios sucks. I have 3 of their scanners and they all drift fairly quickly.
Old 03-18-2018, 2:40 PM
RRR RRR is offline
Cool
Real men use 24 hour time, over!
Ok, we know the G4/G5 isn't a scanner......
Old 03-18-2018, 3:41 PM
03msc's Avatar
Copy that, clear at 15:46. (despite the forum time being off by 5 minutes...)
/s
Mark Arkansas
Uniden Whistler Kenwood Yaesu
Old 03-19-2018, 7:00 AM
On a related matter, why doesn't the clock also make use of use the stored date so it can shift to daylight savings time? Is this a possibility for a future update?
Old 04-08-2018, 1:46 PM
Regarding charging the clock battery in TRX-2, can I use a USB wall charger rather than plugging in the USB cable to PC to charge? I assume yes but wanted to double check. I prefer not powering on the TRX-2 for days to charge that battery.
Also can I turn off the clock (in EZ scan or via menus)? Thanks
Old 04-08-2018, 1:51 PM
Ed6698's Avatar
Yes on both questions.
WS1080 WS1095 PSR500 PRO95 BC200XLT x2
Old 04-08-2018, 3:39 PM
trp2525's Avatar
...If it's like the clock in my WS-1098, it won't keep reliable time anyway...mine was off by more than 10 minutes in a month...
...I set the clock and then after several weeks it is way off...
I have a suggestion to keep the clocks "somewhat accurate" at least on a weekly basis. What I do is to send my computer's time to both of my Whistler scanners (TRX-2 and officially upgraded PRO-668) each week just prior to loading the RR weekly update into the scanners. Just click on "Set Real Time Clock to Computer Time" in the "Scanner/SD Card" drop down list to send the correct/accurate computer time to the scanner. Because some of the scanners' clocks drift much more than others this suggestion may or may not be useful to you. The clocks in my TRX-2 and PRO-668 drift off at different rates. YMMV
trp2525
RCA 16S400, Regency HX1500, PRO-2006, PRO-197, TRX-2, BC950XLT, BCD996XT, BCD396XT, SDS100, Motorola Minitor II, Antenna Specialists MON731
Tags
clock, trx-2, whistler, whistler scanners
