Old 06-05-2017, 7:37 PM
Dtmaster2008's Avatar
Default Trx 1 scan list issue
I finally separated everything I had to certain scanlists the way I liked them to be and enabled them via the scan list tab but when I load the configuration to the scanner it doesn't register and uses what the scanner had it set as, anyone know what could be the issue with it?
Old 06-07-2017, 11:53 AM
Moderator can delete, I figured it out without much issues after I posted the thread
Old 06-09-2017, 7:32 AM
TailGator911's Avatar
Just curious, what was your issue? I had the same issue, then when playing around with it I found that the prior uploads were there in Vscan folders. Opened up the right one and voila, there was my new configuration. This scanner takes some time to get to know, and it's a day to day learning process, but I am happily making progress here. Hope you enjoy the radio!
JD
kf4anc
SDS100, TRX-1, BCD536HP, WS-1065, BCT15X, BC895XLT, PRO-2006, PRO-2035, BC125AT, PRO-2051
ICOM R75, ICOM 746 PRO, YAESU FRG-7, YAESU 2800M, YAESU VX-7R, YAESU FT-2DR, FT-857D
SDR#
Old 07-09-2017, 9:33 AM
Default Scanlist Problem
My problem is, I built a new scanlist, enabled it, saved and uploaded to card, but when I turn scanner on it says Nothing to scan.
Old 07-09-2017, 1:06 PM
Found it, go into the Advanced Features Tab, make sure you have all of your scanlist in this box and enabled .
Old 07-11-2017, 8:46 AM
Thanks for that! I learn something new everyday with this scanner. Just when you think you got it - ya don't lol
JD
SDR#
