Old 06-30-2017, 12:04 PM
WhistlerWendy's Avatar
Whistler Representative
Smile Update - 6/30
Hi everyone!
Happy Friday!!
There will be an update today around noon Central time (possibly earlier depending on how quickly I can get everything ready).
There will be an update to the:
PC App
CPU
Remote Control (new remote control protocol will also be available)
*** Release Notes ***
CPU - change to remote control command
PC App
* Fixed an issue with updating objects from the library where alpha tags could be incorrectly applied
to the wrong objects under certain conditions.
* (TRX Only) Fixed an issue with updating NXDN conventional objects from the library.
* Corrected an issue where incorrect radio IDs may be displayed on recordings in certain cases. Radio
IDs are not always available in recordings.
Previous Release
* Added progress bar to conventional import from a text file/clipboard when more than 25 items are
being imported.
* Fixed issue where conventional import would attempt to import the header row under certain cases
and display an error line.
* Corrected issue where the uninstall information was showing an incorrect version number.
Remote Control
This is still a DEMO and the protocol has been provided for 3rd party developers to experiment and to create their own remote control UI.
Old 06-30-2017, 12:33 PM
Thanks. Just got the email from Whistler on the release of the new firmware to download or update it thru EZ-SCAN
Old 06-30-2017, 12:38 PM
br0adband's Avatar
Same here, just got the email myself too and now that I finally have a Pro-668 converted (not the "official" way) I'll just have to wait and see what this update does for others. I intend to get official upgrade done by Whistler in the near future, but for now it's nice to finally have a proper digital scanner after so many years - my first one after being "The Analog Kid" for scanning purposes since the early 1970s.
<yes, Rush is my favorite band, always...>
The difference between genius and stupidity? Genius has limits.
Old 06-30-2017, 1:25 PM
"And the boy pulls down his baseball cap and covers up his eyes"
Old 06-30-2017, 1:44 PM
N2MWE's Avatar
Connected the scanner, started to download. Scanner is now stuck Boot Ver F2.0, App Ver None Waiting for USB. Pulling batteries and turning on again does nothing. Nd tnis is an upgraded pro 668
I've done my bid for king and country
Old 06-30-2017, 1:56 PM
mikey60's Avatar
What were you using to update it?
If you're using ezScan make sure you have the latest version.
If you're using the update program from the Whistler web site, make sure you downloaded the version for the Legacy Upgraded scanner.
Try again and you should be ok.
http://www.psredit.com
Old 06-30-2017, 2:18 PM
N2MWE's Avatar
Yeah, I got it, Mike, thanks. Just a quirk in the system! I updated my TRX 2 and once again getting the 4-00 error. I get this quite freqently when I update the library or V folders. Starting to get annoying resetting every time I update.
Old 06-30-2017, 2:27 PM
tumegpc's Avatar
Originally Posted by WhistlerWendy View Post
Hi everyone!
Happy Friday!!
Remote Control
Thanks Wendy for the update !
DonS,
We sure can use a version Win500 for the TRX . WinTRX !!
SCANNERS:
Whistler TRX-1/ TRX-2 with DMR - NXDN fully supported
Uniden 536HP/436HP with DMR - { NXDN not supported }
Uniden Home Patrol 2 { DMR- NXDN not supported }
Old 06-30-2017, 3:31 PM
AlphaFive's Avatar
Default bottom update function
Good afternoon all, thanks for the new update. For some unknown to me reason. I ended up having to use the 'check for all updates' function key, instead of the individual list above, in the UPDATES section of EZ Scan. I attempted to update using the function on the individual CPU FIRMWARE key many times, and the process in EZ Scan went flawlessly. The program told me everything worked, and done.
Each time I checked the firmware version in the TRX 2 manually through global settings, the old version sat there, staring back at me.... I tried many different functions, formatting the SD card etc... many things, same result.
I used the 'check for all updates, and it took. Don't know why, if someone is having the same difficulty, try what I did.. Windows 7, original SD card, TRX 2. Take care
Probably not necessary to add this, but I will, each time I successfully used the individual function key for CPU Firmware update, and was told the update completed, I went back to check again on the same key. At that point, each time I was told the new update was available and I had only the old version... That is why I manually checked in global settings.
"I am serious, and don't call me Shirley" - Dr. Rumack 1980
Pace 1000B Pro 2020 Pro 34 Pro 94 Pro 197 BCD536HP TRX 2
Old 06-30-2017, 4:42 PM
fdnyfish's Avatar
my PC app didn't see a update. I have Version 2.23 - June 12, 2017 (for the 1095). Is there a newer version?
Retired FDNY*EMS Captain
KB2MXV
Old 06-30-2017, 5:04 PM
AlphaFive's Avatar
Default update
I can tell you that for my TRX 2 today, the new update was number 4.6, the old one was 4.5.
Old 06-30-2017, 5:06 PM
bravo14's Avatar
I've updated the PSR800 to the new update so far it went through with no problems installing.
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800 BCD536HP BCD436HP HomePatrol-1
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
pro106import's Avatar
Location: Milford, Ct. perched high above Long Island Sound
Wow love the logging feature on the updated Control Demo. Just a quick note, when the program logs a NAC tone, it logs it in the decimal mode on the control program screen, BUT, when you open up the CSV file created, it IS in hex form, which is great.
Bob
Old 06-30-2017, 7:34 PM
johnnyelectron's Avatar
So Wendy, the people who sent their pro-668 to Whistler for the update, is there a different update for them than everyone else, or do they use the same update as the Whistler 1080?
Old 06-30-2017, 7:47 PM
Mine didn't either. Just the CPU update was installed on my WS 1095
Just a couple scanners!
Old 06-30-2017, 8:33 PM
When the units are updated ,they become basically a 1080, so forget it's a 668.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 06-30-2017, 8:43 PM
Kel's Avatar
Kel Kel is offline
After I updated my CPU iit worked for a while them my card corrupted,a first for me,I had code 3-03 pop up,since fixed it .
Old 06-30-2017, 9:57 PM
VicradioZone's Avatar
Greatly appreciate the updates Whistler!
Just updated the relevant PC App, CPU and Remote Control for my TRX-1 and really enjoying having the ability to let the TRX run free and log away without getting square eye syndrome.
Kudos to the team.
Regards,
Vicradio Zone
UBCD996T UBCD396XT TRX-1 XTS5000 FRG7700
Old 06-30-2017, 11:12 PM
What he said
Old 06-30-2017, 11:53 PM
When the units are updated, they become basically a 1080, so forget it's a 668.
What he said
But bizarrely the stand alone CPU updater for the officially converted legacy units is different from the one for the "real" WS1080/88.
Tags
trojan malicious code, whistler scanner
