Old 07-15-2017, 10:43 PM
Default Smaller micro SD card?
Has anyone tried using a smaller micro SD card to speed up boot times?
Old 07-15-2017, 10:48 PM
Ed6698's Avatar
Yes, I have used a 2gb and 1gb sd card, I have even used a 1gb card partitioned to 512mb.
WS1080 WS1095 PSR500 PRO95 BC200XLT x2
Old 07-16-2017, 12:36 AM
RDGDigital's Avatar
I've been using a 256mb card in my WS1080 for about a year now with no problems.
Rick
TRX-1 | WS1080 | PSR-800 (with WS1080 Firmware)
Old 07-16-2017, 2:17 AM
ecarvalho's Avatar
does it really speed up booting?
Icom IC-PCR1000 / BCD536HP / GRECOM PSR-800 / BCD996P2 / TRX-2 / Unication G4 & G5
Old 07-16-2017, 8:37 AM
I tried a 2GB card, timed it, and made no difference. Load time was exactly the same to the second. Maybe results will vary, but not in my case.
SDR | UNICATION G4 | TRX-2 | TRX-1 | BCD536HP | BCD436HP | HOMEPATROL-II | BCD996P2 | PRO-197 | PRO-106 | BCD396T | BR330T | IC-R2
Old 07-16-2017, 10:14 AM
I think it's only the first bit where the display shows 00% then 10% then 20% up to (very briefly) :0% that gets slower on a larger SD card. On my WS1088 it's before the light comes on.
The next bit where the bar moves across seems to be slower only according to the amount (size? number?) of the files on the card.
Old 07-17-2017, 10:06 AM
memory size has nothing to do with read / write speeds of the card.
Each memory card has a class which determines its speeds.
https://kb.sandisk.com/app/answers/d...performance%29
What may limit this is the bus speed of the card reader and the software that reads the card on the scanner.
Old 07-17-2017, 10:10 AM
ecarvalho's Avatar
I thought the same. In terms of booting I don't typically turn my scanners in a hurry. Doesn't mean that the occasion might not arrive...
Say, I see the fire fighters coming to my neighborhood, I might want to power up quickly to find out what is going on, after I run outside to see if my house is safe hehehe
Old 07-17-2017, 12:14 PM
My scanner is on 24/7...I just turn the volume down when I go to bed.
Old 07-17-2017, 12:18 PM
That's great with most scanners but it means using external power which, at least with my WS1088, means it would be vulnerable to unexpected power loss which makes it lose all recordings made since it was last switched off properly.
Sent from my SM-N9005 using Tapatalk
Old 07-17-2017, 12:23 PM
Never had the problem, Plugged in using a wall wart and Nicads inside. The recordings are on the sd card inside and can usually be pulled off with a card reader.
Old 07-17-2017, 12:34 PM
If I switch off the wall wart the scanner almost always crashes and fails to flush something (the FAT and the folders I presume) to the SD card.
Old 07-17-2017, 1:11 PM
2 things that should be obvious....DON'T switch off the wall wart and have rechargeable batteries in the scanner for battery back up. The scanner will charge the batteries and keep them charged. A good set will last 5-8hrs. I did this for 2 yrs will my 668 that I recently sold.
Old 07-17-2017, 1:13 PM
EXACTLY.
But power can fail.
Old 07-21-2017, 8:01 PM
I found that NOT putting the whole U.S. database on the card increased my boot time.
Old 08-03-2017, 3:42 PM
I found some 256 MB cards on eBay. After some fighting with them, I got them working. My scanner boots up a second or two faster now.
Old 08-10-2017, 7:59 PM
I put a 32gb card in mine and it booted SLOWLY. I put an 8gb card in and it was much faster.
After booting both cards worked perfectly...and both are class 10 sandisk cards. I don't know why the big card slows boot so much...but it really does.The initial count is glacial with it.
Pro 2006, Icom R100, Icom R-8500, Homepatrol 2, TRX-2
Old 08-10-2017, 10:23 PM
I'm pretty sure it's reading the entire FAT so that it knows which allocation blocks are free. Since the allocation blocks are always 32KB the FAT's size is proportional to the size of the card.
Old 08-10-2017, 11:40 PM
I am sure you are right...it is slow though!
