Old 08-21-2017, 9:53 PM
KenFL9's Avatar
Default Railroad NXDN Conventional
I have a new TRX-1 and it is receiving railroad analog transmissions on channels 007 through 097 very well. As a railroad contractor I have a Kenwood NX-210 portable and a NX-700 in my SUV. Both are programmed with NXDN channels 307 through 487 in one of the groups although I have yet to actually use them at work.
I programmed a scanlist in my TRX-1 with the appropriate frequencies and set everything to NXDN with RAN 0 (and I also tried "any"). When I test it with either of my radios on a specific channel with the TRX-1 an appropriate distance away to avoid overload the scanner shows no reaction visibly or audibly.
Any thoughts on how I should be programming the settings and or what I am missing?
Thanks!
Old 08-22-2017, 9:17 AM
werinshades's Avatar
Thanks!
Are you programming the input frequencies in? Maybe the NXDN repeaters haven't been activated yet?
Old 08-22-2017, 9:41 AM
KenFL9's Avatar
These are all programmed as simplex frequencies. No repeaters.
Old 08-22-2017, 11:15 AM
W2GLD's Avatar
Try putting the scanner in manual tune search mode, enter the known frequency only, then see what's being transmitted from the actual NXDN radios. I'm tracking several here and it works just fine, no issues.
Old 08-27-2017, 4:16 AM
f you already know tx frequencies,set all of them as conventional in same scan group,then start to scan.
Old 10-10-2017, 1:36 PM
wa8pyr's Avatar
Technischer Guru
Any thoughts on how I should be programming the settings and or what I am missing?!
I ran into this at Bellevue, OH over the weekend, having taken my TRX-1 along just to search and see if anything was using NXDN in the yard. It was.
I have a scan list called RR Search (List 99) set up with all the RR frequencies pre-programmed, analog channels set to Analog and NXDN channels set to Digital. Analog worked fine, but when 160.7325 digital came up active it would not stop on AAR 376 as it should have, instead kept stopping on the analog channel making all kinds of racket.
I finally had to set the digital search channel to DG Mode - Auto, RX Mode - Auto and Sq Mode - Srch to get the digital traffic to come through, after which it did fine, showing RAN=0 during active transmissions. I then added that channel to the normal "confirmed" railroad scan list (list 100), and once again, nothing. I had to tinker with the settings until it started working. Still not sure exactly what I did to make it work, but try this:
DG Mode - Dig
RX Mode - Auto
Sq Mode - Srch
Sq Search - checked yes
NXDN - checked yes
RAN - Any
RadioID - checked yes
RID - Any
If that doesn't work try setting RAN to 00. I can't recall if RAN 00 is "pass any RAN" or "pass only stuff that doesn't have a RAN."
I really need to sit down and monitor some conventional NXDN around here, and play with the settings to confirm what really works.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
Old 10-11-2017, 2:16 AM
alabamarailfan's Avatar
Hey Guys,
I guess I got lucky as I never put any of the new frequencies in. I had one scan list with all the 1-97 AAR list, all set as analog. I have a second scan list, same frequencies but the mode set to NXDN and had no problem catching the NS car-men working on AAR 79.
https://www.youtube.com/watch?v=RlEadey0axY
I guess if they had been using one of the narrower band frequencies, I would have had trouble. I might need to check again with those channels entered. Hope this helps, Ken.
-- John
John D. Peterson/W4JDP
Decatur, AL Railroad Scanner Feed:
http://www.alabamarailfan.com/live-scanner.php
Decatur, AL Public Safety Scanner Feed: http://www.alabamarailfan.com/pubsafety.php
Old 10-11-2017, 10:51 AM
KenFL9's Avatar
Default Thanks for the updates!
Thanks to both Tom and John!
I will experiment with those settings here and let you know the results.
Old 10-12-2017, 10:49 AM
Muxlow's Avatar
Same deal here in Canada. Seems all CN Rail workers have NX700/NX210's but havne yet to hear any digital comms.. All just analog still. Wonder if the NX channels are just for common use if they venture across the border or to have comms with US trains or whatnot?
Muxlow
..Yeah iv got some radios
