Ubbe's method will work as described.
If you only have one frequency, you can also create a conventional object that is set to DMR just to see what is on the frequency. It is a faster process than creating a full trunk system and may be all you need and helps in the analysis process.
It really depends on what type of DMR system you are looking at.
