Old 05-11-2018, 10:02 AM
iMONITOR's Avatar
Question Spectrum Sweeper?
Does the 'Spectrum Sweeper' feature on Whistler scanners perform equally well on all models, or are some better than others?
Old 05-17-2018, 12:34 AM
Melv7956's Avatar
Some people report it picks up nothing but both of mine kick the *** out of close call. Not as quick as close call but picks up far more.
Old 05-17-2018, 3:29 AM
Spectrum Sweeper needs to have all those Zeromatic parameters intact and correctly set to make it work. Sometimes you'll need to reset to default as they can get corrupted or plainly disable zeromatic to make the best use of Spectrum Sweeper.
/Ubbe
