  #21 (permalink)
Old 09-28-2018, 4:42 PM
djeplett's Avatar
Originally Posted by lolbananalol2 View Post
What do the delay settings do?
If you are referring to the programmable delay time for each object then that simply tells the scanner how long to pause on that object to listen for replies. It has nothing to do with the length of any squelch tails.
W9DJE
Whistler TRX-1 * GRE PSR-500 * Radio Shack PRO-2055, PRO-106 * Yaesu FT-7800R, FT2DR, FT-8900R, FTM-350AR * Kenwood TS-570D, TK-380, TK-760H, TK-762HG * /\/\ XTS3000 Mod III
  #22 (permalink)
Old 09-30-2018, 6:08 PM
mrkelso's Avatar
Originally Posted by Skypilot007 View Post
On my TRX-2 with the squelch set at 9 the squelch tail is acceptable but this setting of 9 sets the squelch threshold to high and weaker transmissions that I want to hear are squelched out. Dropping the squelch down to 8 or 7 brings on the long squelch tail problem.
I too have reported this to the whistler many months ago and nothing has been done.
Yes, this is exactly the problem.
  #23 (permalink)
Old 10-08-2018, 4:51 PM
mrkelso's Avatar
An email about this problem has been sent over to the Engr to look at. I got this from a high up source
  #24 (permalink)
Old 10-09-2018, 11:16 AM
Skypilot007's Avatar
By the time they fix this problem I'll be ready to sell it to get one of the new mobile scanners that may actually work on a phase II LSM system. Good grief.
  #25 (permalink)
Old 10-09-2018, 11:20 AM
djeplett's Avatar
Yeah, I won't be holding my breath either.
W9DJE
  #26 (permalink)
Old 10-10-2018, 4:03 PM
mrkelso's Avatar
I am holding out for a fix or I won't be buying anything new from them. Same goes for Uniden.
  #27 (permalink)
Old 10-11-2018, 10:42 PM
Originally Posted by Ubbe View Post
A modern car has a lot of electronic "smog" and my experiance are that it mostly appears in VHF and LO-VHF.
Yep - in some of my mobile installs, both the Unidens and Whistlers get hit hard by the junk emanating from the dash.
One solution, with antennas in the rear of the vehicle, is to use #43 type (30-300mhz) ferrite chokes near the input of the scanner, AND near the feedpoint of the antenna itself.
That got rid of much of the common-mode interference hitting the coax braid, and eventually traveling back down inside the coax to the scanner.
Mag-mounts are particularly prone to common-mode interference, so we drilled holes (gulp!) for a good quality nmo-type mount.
Still, in stubborn cases direct reception by the antenna itself, and not the common-mode problem of the braid, can lead to head-aches no matter what.
