Old 10-27-2018, 8:19 AM
wbswetnam's Avatar
Default DMR conventional + private calls on WS-1095
A local PD uses DMR conventional. How do I entice my WS-1095 to monitor unit-to-unit private calls?
Too much of a good thing can be wonderful. - Mae West
Old 10-27-2018, 8:26 AM
I've read in another forum about the TRX that adding a wildcard in the Radio ID allows you to do this. But I don't know if you can do this in your scanner.
Sent from my LG-Q710AL using Tapatalk
Whistler TRX-1, Radio Shack Pro-668 (mod), Pro-197, Pro-651, Pro-106, Pro-96
Baofeng 888, UV82, UVB5, Connect Systems CS750
Old 10-27-2018, 8:32 AM
wbswetnam's Avatar
That only works with DMR trunked systems, not single frequency conventional.
Old 10-27-2018, 8:33 AM
Thanks I wasn't aware of the details
Old 10-27-2018, 8:49 AM
Melv7956's Avatar
You can tell the radio via programming that it is a trunk system or at least you can with the trx models you then enjoy the added benefits of adding names to radio idís and private messages.
Old 10-27-2018, 9:34 AM
To monitor private calls with my 1088, I either check the RadioID box in the menu for that particular object, or change the set item for squelch from Talkgroup ID to Radio ID.
It's interesting to note that doing this not only opens up the radio to private calls, but it also still allows all group TGs to pass through as well. Because of this, I keep all my DMR conventional frequencies on the Radio ID setting.
wbswetnam's Avatar
You can tell the radio that a single frequency conventional system is trunked? Programming method?
Old 10-27-2018, 9:39 AM
What he's describing is programming the radio under the "trunked systems" tab. There are many perks to doing this, but you'll sacrifice about a second of your scan time just to monitor one particular frequency.
This can be done, especially because on a Whistler the radio will monitor the trunked system by conventionally scanning the frequencies.
Old 10-27-2018, 10:23 AM
N8IAA's Avatar
Exclamation
What he says in Post 6. How I do it with my 1088. This also works with P-25 conventional.
Larry
Old 10-27-2018, 11:32 AM
Larry
That's interesting, I didn't know that this could be used for P25.
How do you program for a P25 private call using the software?
Old 11-01-2018, 8:19 AM
Melv7956's Avatar
Plus you get the added bonus of being able to give the radio numbers names which will then come up when they transmit which you canít if programmed as conventional.
Old 11-01-2018, 2:44 PM
wbswetnam's Avatar
I figured out how to program a conventional DMR one frequency as a "one frequency trunked" system. It is coming up with the wildcard! now so I guess I did it right. Now I'm just waiting for the dispatcher to say "Go to ten"; then we'll see if this work-around is correct.
Old 11-09-2018, 2:27 PM
tmfok7's Avatar
I have some theories but.... how exactly did you do it?
Blessed are the flexible... for they shall not be bent out of shape!
______________
Too Much Fun...OK!
