09-21-2009, 02:32 PM
Civil Air Patrol Problem
When I try and go to the Civil Air Patrol link in the wiki I keep getting a blank page.
Steve
BC396T Scanner
Pro-2045 Scanner Discriminator Tap
ARC396TPRO Software
09-21-2009, 02:56 PM
Working Fine here, just loaded it. Maybe you need to reboot
There were many changes made to it today
Steve
09-21-2009, 03:10 PM
Just tried again
Just tried the link again after re-booting my computer and it still does not work, the page comes up for a second and then goes blank ??? Also all other links in the wiki work ok.
Steve
BC396T Scanner
ARC396TPRO Software
09-21-2009, 03:25 PM
Steve
I can't get it to load either! Does the same thing for me as Saint describes.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
09-21-2009, 03:26 PM
Hmmm, working fine on more than one Computer here.
Anyone else??
09-21-2009, 03:33 PM
Anyone else??
I don't know if it makes any difference or not, but the link that is posted by Saint is not blue, but a purple color like the color it would go after you have clicked on it. I also went to the Wiki Home page, entered Civil Air Patrol in the search box and got the same results: a flash and then blank page.
Running XP Pro, IE 8.
09-21-2009, 03:48 PM
I think a Moderator needs to take a look at this.
I can load it fine, until... I log Out as a WIKI Editor. Once Logged out, it does the same thing, Quick Load to a Blank White Page.
If I log back in, all is showing Fine.
Moderator, the changes made today were I added Tables [template] to allow sorting of the Data
09-21-2009, 04:37 PM
Yup, same thing happens to me, loads and then blanks.
09-21-2009, 06:09 PM
Same here...appears then quickly disappears.
The Honourable Path A. Logical, Minister of Scanners, B.Sc., (Bachelor of Scanners)
...lookin' up at the sky, to see who's flyin' by... ...listening to all the voices in my scanitarium...
09-21-2009, 06:39 PM
Same here too. WTF???
Bluegrass1DCR1/KI4RDG
Derby City Radioactives
Louisville METRO
REACT ARES RACES SKYWARN
Bluegrass1DCR1.bravehost.com
DerbyCityRadioactives.com
LouisvilleScanMan.com
09-22-2009, 08:05 AM
Rather ODD. The RR WIKI doesn't like WIKI Tables.
The only change made was to put the info into a Table [Sortable]
I just removed the table info [left the pipes || for now] until they can look into the issue.
Can someone try and check the page, I think it's back
09-22-2009, 08:34 AM
Moderator
It would appear that the "skins" template is missing and you hang (on a blank page) while it looks for it on the servers; no doubt as a result of the migration to the new servers.
This is something Mike needs to get Lindsay to work on.
09-22-2009, 08:44 AM
Is it loading ok, now ?? I removed the table info, as we have added more and more info to it, hate it to be lost until the issue get's resolved.
09-22-2009, 08:56 AM
Kentucky DB Admin...
yes, it is loading fine now
09-22-2009, 09:08 AM
Moderator
I'm sorry, I should have been more clear. Yes, it is loading fine in its present state, I was looking at the previous version trying to see what the problem was.
09-22-2009, 10:33 AM
Rather ODD how it loaded fine when LOGGED into EDIT the WIKI, but when NOT logged in, all the problems occur.
09-22-2009, 01:29 PM
I just clicked on the link in post #1, was taken to the CAP page, and it loaded without difficulty so I can confirm what trashman says. I might just add that the color of the link in post #1 remains a purple color. Still not sure if that has any importance.
09-23-2009, 10:07 AM
Wiki Admin
The problem might be a service or statement that the wiki doesn't understand. I see in the change logs where a template was called - but when I try to edit the template code, my session gets wiped out and I get locked up. There are 2 templates on the Scan New England wiki with the same names, but these seem to work, indicating something is installed in the SNE wiki that the RR wiki does not have.
The templates on the SNE Wiki are 'prettytable' and 'largetable'. I can't look at the code on that wiki from work, so it will have to wait until I get home. 73 Mike
09-23-2009, 08:19 PM
Wiki Admin
The problem is that these SNE templates call a java class that evidently doesn't exist here on RR. I dropped the class statements off a copy of these templates and they worked, although I'm unsure that they worked the way it was originally intended.
Not a RR wiki table problem, as I suspected. 73 Mike
09-24-2009, 07:45 AM
Thanks Mike, I will try and enable it again.
Hopefully
Thanks Mike, I removed the java class, it was used to allow a SORT of the tables, which works when you want to sort by the fields.
It's apparently not enabled on RR, but is on SNE
thanks
