Go Back   The RadioReference.com Forums > Site Administration Forums > Wiki Forum
Wiki Forum - Discussions regarding the RadioReference Wiki
Old 11-12-2017, 9:39 AM
Default Wiki article damaged
I don't know if this was intentional or not but it looks like somebody went to
http://wiki.radioreference.com/index.php/Medevac_(TX)
and reverted it back a few years. This changed the categories, templates and return-to links that were implemented a while back.
Tom
Old 11-12-2017, 1:15 PM
Wiki Admin Emeritus
It's pretty simple to undo this. See the HISTORY link on the far lett when looking at the article? Click on that, then select the most recent time period that you believe to be correct. Click on Compare; you will then be presented with 2 versions; edit the version you wish, then at the bottom of the article, hit SAVE.
No need for any mod intervention here..Mike
co-author, HF Digital Decoding
Old 11-12-2017, 1:54 PM
I should have tried that. For some reason I thought that only worked if an admin did it.
Tom
Old 11-12-2017, 3:37 PM
Wiki Admin Emeritus
Nope anyone can do this. The restriction of an admin only applies to deleting articles - makes it somewhat harder for a spammer - which we've had a few - to come in and do real damage
Old 11-13-2017, 12:53 PM
Now the page shows "There is currently no text in this page...."
Bill
N4GIX - Ham / WQWU626 - GMRS
TK-840(N), TK-880-1, 2xTYT-7800, 2xUV5R v2+, HP1, BCD436HP, TMV7A, 2xRitron RRX-450 Repeater, MD-380, XPR7550, 2xCS800, BCR-40U Repeater, IC-7300, G5RV-JR
Old 11-13-2017, 1:19 PM
Spitfire8520's Avatar
The automatic link generator doesn't like the ")" character. If you go to the actual Medevac (TX) article, you will find that the article is there.
Mile-High Spitfire
RadioShack Pro-106 RadioShack Pro-652 RTL-SDR
MNN-250
Old 11-13-2017, 1:41 PM
Ah, this works:
Medevac (TX) - The RadioReference Wiki
Instead of the parenthesis, it is using %28 and %29
Bill
Old 11-13-2017, 2:14 PM
Wiki Admin Emeritus
Unfortunately this is a long standing issue with the rightmost paren that has never been addressed. Very annoying...Mike
Old 11-13-2017, 3:33 PM
I forgot about the ) problem when I made the original post. I fixed the wiki article in question so no need to continue this thread.
Tom
